 Post subject: SEAGATE 7200.10 HELP
PostPosted: August 11th, 2009, 7:33
Hello everyone I very much appreciate your views, I have a Seagate 7200.10 alloy enter into readiness and not detected in bios, like the suggestion to anyone who can help now thank
TERMINAL
Reset
4096k x 16 DRAM
GALAXY - 1_Disk S-6D 09-22-06_15:48
Buzz HM SFI
(P)SATA Reset
DiskAccess ReadSector EC=47 at ffffffff.00.0002
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
DiskAccess ReadSector EC=47 at ffffffff.00.022b
Failed sys sect. write! Nwt Er 00 RdWr 1613a.00.022b
DiskAccess ReadSector EC=47 at ffffffff.00.0080
Unable To Load Overlay 01|000A
T>Age=50 Type=18 MxCyl=21135 MxHd=3 MxSct=000 BSz=008M TCode=05060501 ThermFlts=
0000
 Post subject: Re: SEAGATE 7200.10 HELP
PostPosted: August 11th, 2009, 15:58
either bad sectors in SA or weak head.
PostPosted: August 18th, 2009, 19:31
PEPE is right.This disk has the problem of EC=47 at ffffffff.00.0002 and it's Overlay 01 can not load now.If you have the pc3000,you can find a similar FW to load it in the RAM by SDLD,and then you can do the SELFTEST of seagate from age=02. If it can run to AGE=50, you're lucky.IF not ,you'll have to try to cut the HEAD 0,and then run the selftest again.After all, write the ATA0,ATA1 to the correct track,and write the VENDOR track.GOOD LUCK.
PostPosted: August 20th, 2009, 5:39
MASTER Spildit ,do you have some ways to do the HEAD CUTTING of 7200.11 of Seagate?It's big problem I've seen now.I still have no way to deal with.What do you think? :cry:
PostPosted: August 21st, 2009, 9:34
TERMINAL
Reset
4096k x 16 DRAM
Buzz HM SFI
(P)SATA Reset
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
0000
New PC3000 will fix this fault. It will enable you to create LDR from patient using APP code, and has option to repar Unable To Load Overlay 01 error
Users browsing this forum: No registered users and 103 guests
