| SEAGATE 7200.10 HELP http://forum.hddguru.com/viewtopic.php?f=11&t=12972 |
Page 1 of 1 |
| Author: | harddisk [ August 11th, 2009, 7:33 ] |
| Post subject: | SEAGATE 7200.10 HELP |
Hello everyone I very much appreciate your views, I have a Seagate 7200.10 alloy enter into readiness and not detected in bios, like the suggestion to anyone who can help now thank TERMINAL Reset 4096k x 16 DRAM GALAXY - 1_Disk S-6D 09-22-06_15:48 Buzz HM SFI ! (P)SATA Reset DiskAccess ReadSector EC=47 at ffffffff.00.0002 DiskAccess ReadSector EC=47 at ffffffff.00.0002 Read Ver Retrys DiskAccess ReadSector EC=47 at ffffffff.00.0002 Read Ver Retrys DiskAccess ReadSector EC=47 at ffffffff.00.0002 Read Ver Retrys DiskAccess ReadSector EC=47 at ffffffff.00.0002 Read Ver Retrys DiskAccess ReadSector EC=47 at ffffffff.00.0002 Read Ver Failure! DiskAccess ReadSector EC=47 at ffffffff.00.022b Failed sys sect. write! Nwt Er 00 RdWr 1613a.00.022b DiskAccess ReadSector EC=47 at ffffffff.00.0080 DiskAccess ReadSector EC=47 at ffffffff.00.0080 Unable To Load Overlay 01|000A T>Age=50 Type=18 MxCyl=21135 MxHd=3 MxSct=000 BSz=008M TCode=05060501 ThermFlts= 0000 |
| Author: | pepe [ August 11th, 2009, 15:58 ] |
| Post subject: | Re: SEAGATE 7200.10 HELP |
either bad sectors in SA or weak head. pepe |
| Author: | cham_810 [ August 18th, 2009, 19:31 ] |
PEPE is right.This disk has the problem of EC=47 at ffffffff.00.0002 and it's Overlay 01 can not load now.If you have the pc3000,you can find a similar FW to load it in the RAM by SDLD,and then you can do the SELFTEST of seagate from age=02. If it can run to AGE=50, you're lucky.IF not ,you'll have to try to cut the HEAD 0,and then run the selftest again.After all, write the ATA0,ATA1 to the correct track,and write the VENDOR track.GOOD LUCK. |
| Author: | cham_810 [ August 20th, 2009, 5:39 ] |
MASTER Spildit ,do you have some ways to do the HEAD CUTTING of 7200.11 of Seagate?It's big problem I've seen now.I still have no way to deal with.What do you think? |
| Author: | hddguy [ August 21st, 2009, 9:34 ] |
harddisk wrote: Hello everyone I very much appreciate your views, I have a Seagate 7200.10 alloy enter into readiness and not detected in bios, like the suggestion to anyone who can help now thank TERMINAL Reset 4096k x 16 DRAM GALAXY - 1_Disk S-6D 09-22-06_15:48 Buzz HM SFI ! (P)SATA Reset DiskAccess ReadSector EC=47 at ffffffff.00.0002 DiskAccess ReadSector EC=47 at ffffffff.00.0002 Read Ver Retrys DiskAccess ReadSector EC=47 at ffffffff.00.0002 Read Ver Retrys DiskAccess ReadSector EC=47 at ffffffff.00.0002 Read Ver Retrys DiskAccess ReadSector EC=47 at ffffffff.00.0002 Read Ver Retrys DiskAccess ReadSector EC=47 at ffffffff.00.0002 Read Ver Failure! DiskAccess ReadSector EC=47 at ffffffff.00.022b Failed sys sect. write! Nwt Er 00 RdWr 1613a.00.022b DiskAccess ReadSector EC=47 at ffffffff.00.0080 DiskAccess ReadSector EC=47 at ffffffff.00.0080 Unable To Load Overlay 01|000A T>Age=50 Type=18 MxCyl=21135 MxHd=3 MxSct=000 BSz=008M TCode=05060501 ThermFlts= 0000 New PC3000 will fix this fault. It will enable you to create LDR from patient using APP code, and has option to repar Unable To Load Overlay 01 error |
