WD2500AAKS - 00B3A0 Rom
http://forum.hddguru.com/viewtopic.php?f=11&t=13271
Author:  Zero Alpha [ September 4th, 2009, 8:21 ]
Post subject:  WD2500AAKS - 00B3A0 Rom
Anyone have a rom from this disk please
Also can somebody tell me its family name?
Author:  Mikippp [ September 5th, 2009, 8:17 ]
Post subject:  Re: WD2500AAKS - 00B3A0 Rom
WD2500AAKS-00B3A0 -> Pinnacle
Mikippp
Author:  Zero Alpha [ September 5th, 2009, 9:07 ]
Thanks soooooooo much... See if I can fix it now.
Author:  hddguy [ September 8th, 2009, 9:27 ]
do you still need ROM for this?
Author:  Zero Alpha [ September 9th, 2009, 8:25 ]
Yes please, I'm still chasing a ROM.
Author:  drc [ September 9th, 2009, 11:10 ]
Can you not recreate from SA modules?
Author:  Zero Alpha [ September 9th, 2009, 21:01 ]
This drive will not spin up because i'm suspecting a pcb/rom failure. I have a donor pcb from a different family that will spin the drive but I need the correct rom so that I can disable heads as the drive is clicking. It looks like this drive has 2 problems so far, dead pcb and probably dead heads. A rom with correct head map would be very handy for this job.
Author:  drc [ September 9th, 2009, 23:31 ]
I think that will be difficult as you would need to match the version, which if you can't see the modules to get the correct version number will be shooting in the dark...
Author:  Zero Alpha [ September 10th, 2009, 10:00 ]
Yes its going to be difficult. Having 2 separate problems makes it more fun right? My strategy is to get a working ROM then I can diagnose why heads are clicking. Fix the clicking and regen the ROM. Customer gets data back and I earn my income. :) :)
ROM anyone?
