Hi to all,
Have this disk
WD400BB-77AUA1, when i connect to the udma it stays
BSY forever.
So i found a similiar PCB
Patiente: 000 001003-001 G
Donor : 000 001003-000 C
When i change it , i could have ID, serial size, all the modules are ok in the utility, and i see two heads 0 1
I test the SA copy in the Composite reading , Copy 0 , Copy 1, and all the modules are green.
The info from service tracks i have this error but i think is normal for this model
Cyl -9; Head 0.......................... : Ok
WD Techno Read Error C/H/S: -9/1/280 Device Error Detected 59/40 (UNC)
WD Techno Read Error C/H/S: -9/1/327 Device Error Detected 59/40 (UNC)Cyl -20; Head 0......................... : Ok
WD Techno Read Error C/H/S: -20/1/1 Device Error Detected 59/01 (AMN)
WD Techno Read Error C/H/S: -20/1/519 Device Error Detected 59/01 (AMN)Cyl -20; Head 1......................... : Ok
When i start in DE and build the head maps it appear 3 Heads.
i start to clone, and i just can clone 41 215 sectors, after disk it give error reading any sector
Anyone have an opinion about this.
ZeBong
