ST980011A - 80gb pata
Posted: September 12th, 2009, 7:59
by zebong
Hi to all,
Have this in a seagate disk
Interface task reset
1024k x 16 buffer detected
ALPINE - 1_Disk M-21 11-25-03 18:53
Head Mask FFFF - Switch to full int.
Spin Ready
Application code incompatible with serial flash code
F>
Anyone can give an opinion what can i do here,
ZeBong
Re: ST980011A - 80gb pata
Posted: September 12th, 2009, 9:27
by pepe
Somebody swapped the pcb and forgot to swap it back...
Posted: September 12th, 2009, 11:17
by hddguy
You need either the original PCB or its ROM, or as I believe there is no adaptive information on old Seagates, so you could get lucky with an exact matching PCB with same ROM.
Personally, best bet is to ask for native PCB.
Posted: September 12th, 2009, 11:24
by rameez
What is the firmware on drive ?
Posted: September 12th, 2009, 11:28
by zebong
Thanks,
Yes i know i will get lucky in find the same PCB, but i have almost 12 all different from this one.
The FW is 3.06.
Posted: September 12th, 2009, 17:56
by rameez
You need pcb with M14 code .
Posted: September 12th, 2009, 19:33
by zebong
rameez wrote:You need pcb with M14 code .
Hi, yes i think i try that one and did not work the same appear in terminal.
i will try it and post here the logs in terminal.
Posted: September 13th, 2009, 4:46
by rameez
Try S15 also .
Posted: September 13th, 2009, 7:51
by scratchy
Or you could load the existing ROM with correct ROM from another drive or resource file.
Posted: September 15th, 2009, 12:02
by zebong
Thanks to all,
Patient is : 100282774 F 6514GSAY
Buzz - Head Mask FFFF - Switch to full int.
Spin Ready
F>
i try this one 100282774 C 64119VMM
i have this in terminal
ALPINE - 1_Disk M.14 01-16-03 11:51
Head Mask 0000 - Switch to full int.
Spin Ready
F>
Them i try this one : 100282774 E 343247AX
Spin Ready
F>
LAST ONE : 100282774 E 3425YQ6M
Buzz - Head Mask 0000 - Switch to full int.
Spin Ready
F>
and i dont have a loader for the M-21
Posted: September 15th, 2009, 13:35
by zebong
THANKS
S-15 SOLVE
