 Post subject: Compatible Motherboard for PC3000
PostPosted: September 22nd, 2009, 8:22
Hi
Please let me know compatible motherboards for PC3000 to be installed. Do you recommend any particular CPU, RAM size and motherboard type and OS to install PC3000.
Cheers
-Jag
 Post subject: Re: Compatible Motherboard for PC3000
PostPosted: September 22nd, 2009, 10:39
IMHO the best minimum configuration is a 965 (or < ) based mobo and c2d 2.4G P4 with 2GB ram.
If you want good, get an Intel-made mobo.
Janos
PostPosted: September 23rd, 2009, 5:24
NC is right but be careful when you are buying the PCI slot plays a very important role in the configuration of the board and it working correctly. I went through 5 now on 6 mother board to find this one out :(
Iorana Haraharaini
PostPosted: September 23rd, 2009, 5:26
And i never had problems with motherboards, even if its allready the thirth one i use. Strange.
Dobre
Murphy was an optimist
PostPosted: September 23rd, 2009, 8:28
Have attention to the Chipset of the MB.
I do not recommend VIA , don't know what Acelabs tell about this ...
ZeBong
" Россия еще раз"
PostPosted: September 23rd, 2009, 8:48
Ive always used Dell workstations.. never a problem :)
