| Compatible Motherboard for PC3000 http://forum.hddguru.com/viewtopic.php?f=11&t=13455 |
Page 1 of 1 |
| Author: | jag17 [ September 22nd, 2009, 8:22 ] |
| Post subject: | Compatible Motherboard for PC3000 |
Hi Please let me know compatible motherboards for PC3000 to be installed. Do you recommend any particular CPU, RAM size and motherboard type and OS to install PC3000. Cheers -Jag |
| Author: | N.C. [ September 22nd, 2009, 10:39 ] |
| Post subject: | Re: Compatible Motherboard for PC3000 |
Hello, IMHO the best minimum configuration is a 965 (or < ) based mobo and c2d 2.4G P4 with 2GB ram. If you want good, get an Intel-made mobo. Janos |
| Author: | poehere [ September 23rd, 2009, 5:24 ] |
NC is right but be careful when you are buying the PCI slot plays a very important role in the configuration of the board and it working correctly. I went through 5 now on 6 mother board to find this one out |
| Author: | dobrevjetser [ September 23rd, 2009, 5:26 ] |
And i never had problems with motherboards, even if its allready the thirth one i use. Strange. Dobre |
| Author: | zebong [ September 23rd, 2009, 8:28 ] |
Have attention to the Chipset of the MB. I do not recommend VIA , don't know what Acelabs tell about this ... |
| Author: | guru [ September 23rd, 2009, 8:48 ] |
Ive always used Dell workstations.. never a problem |
