 Post subject: Problem with HTS421280H9AT00
PostPosted: October 7th, 2009, 9:01
Hello
Can someone help me with this hdd
this is a problem of the fw or hardware?
Start SA checking.rar [4.34 KiB]
Downloaded 570 times
 Post subject: Re: Problem with HTS421280H9AT00
PostPosted: October 7th, 2009, 9:06
Is the drive ID'd OK in PC3000? With correct model, sn and LBA?
What happens when u try and view a sector in "sector edit"?
PostPosted: October 7th, 2009, 11:05
Testerday my id and serial is right and i saved sa report.
today pc3000 says hdd not ready what is my mistake?
PostPosted: October 7th, 2009, 13:18
Try to find donor ldr file and check SA I had this same problem once. It is some modules in SA that were damaged that needed to be replaced. Good luck maybe it is same problem for you like for me.
Iorana Haraharaini
PostPosted: October 7th, 2009, 17:20
This can be media damage, wich damages the head too.
But of course it can be SA problem too, like the other gurus sad....
I think more change in this drive (mobile drive) for head/platter damage.
Janos
