 Post subject: Maxtor 4R120L0
PostPosted: October 30th, 2009, 8:35
I'm looking for a LDR for this drive:
Model: 4R120L0
Code: RAMB1TU0
If you can help, it would be appreciated.
Thanks,
 Post subject: Re: Maxtor 4R120L0
PostPosted: October 30th, 2009, 8:47
Here i have one for an 160G drive.
Should work also.
Dobre
Maxtor 4R160L0 RAMB1TU0-8240-R415B2LE.rar [1.08 MiB]
Downloaded 618 times
Murphy was an optimist
PostPosted: October 30th, 2009, 8:48
Thanks,
Will give it a try in a couple of minutes.
PostPosted: October 30th, 2009, 9:13
Doh! Anyone got the PC3000UDMA LDR file for this drive?
PostPosted: October 30th, 2009, 9:32
Not working ?
Dobre
PostPosted: October 30th, 2009, 9:37
I renamed it from .pcr to .ldr, but it does not work.
LDR does not contain overlay 1B
PostPosted: October 30th, 2009, 9:41
NO, the pcr file has to be loaded in the UDMA database !
Open the database, choose import and select the pcr file.
:D
Dobre
PostPosted: October 30th, 2009, 9:46
Good point...it has been so long since I've imported into the database, I forgot it even existed. Thanks for the wake up call.
PostPosted: October 30th, 2009, 9:51
Yup, that worked better and helped me confirm that the problems are internal. Now it is time for a visual inspection...I suspect that it is toast.
PostPosted: October 30th, 2009, 9:59
Glad this worked. :)
You dont happen to have a loader for a Athena DSP 20B020H1 with code WAK21R90?
Dobre
PostPosted: October 30th, 2009, 11:03
Sorry...I don't have that one here. I'll get someone to check and see if we have a drive from which we can make a LDR for you.
PostPosted: December 1st, 2009, 18:17
it is for PC3000 PCI OR UDMA?
PostPosted: December 2nd, 2009, 4:12
Thanks Ccamargol, but this case has been solved in the mean time :)
Dobre
Users browsing this forum: Google [Bot] and 22 guests
