| WD800BB-00JHC0 id'd as Sabre but tests ok (mostly). http://forum.hddguru.com/viewtopic.php?f=11&t=13750 |
Page 1 of 1 |
| Author: | gbulger [ October 27th, 2009, 5:50 ] |
| Post subject: | WD800BB-00JHC0 id'd as Sabre but tests ok (mostly). |
I have a WD800BB-00JHC0 drive just in with exactly the same problem that I had with the same drive 3 weeks ago. I haven't been able to fix either drive. Any help would be appreciated. The drive ids as Sabre. SA verification is ok. SA structure test ok, All service tracks read, all service modules read ok, heads test ok. Service area surface and write tests ok. Transferred rom to an identical donor - Now it still Id's as Sabre. Customer confirmed that it has the original pcb. ----------------------------------------------------------------------------------------- This is the error message seen as the drive id's itself: Techno mode key Techno mode key......................... : Ok RAM: Zone allocation table................... : HDDs RAM reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED" SA SPT.................................. : 533 Head number reading..................... : Ok Heads number............................ : 2 ROM: ROM reading............................. : Ok ROM Data size........................... : 128 Kb ROM version............................. : 08.8FC ROM generation.......................... : 08.8FC Link table version...................... : 01.B0. Heads configuration..................... : by map Heads number............................ : 2 Heads number in use..................... : 2 Switched off heads...................... : No Head map................................ : 0,1 Service area: SA dir reading.......................... : Ok (Copy 0) Configuration reading................... : Ok Master Password......................... : has not been set User Password........................... : has not been set ------------------------------------------------------------------------- When I try to regenerate the translator using Plist I get the following error: Heads number............................ : 2 Heads number in use..................... : 2 Switched off heads...................... : No Head map................................ : 0,1 Service area: SA dir reading.......................... : Ok (Copy 0) Configuration reading................... : Ok Master Password......................... : has not been set User Password........................... : has not been set SA surface verification Cyl: -1 Head: 0 Break................... : Ok SA surface verification Cyl: -39 Head: 0........................ : Ok Cyl: -40 Head: 0........................ : Ok Cyl: -41 Head: 0........................ : Ok SA surface verification Cyl: -39 Head: 0........................ : Ok Cyl: -39 Head: 1........................ : Ok Cyl: -40 Head: 0........................ : Ok Cyl: -40 Head: 1........................ : Ok Cyl: -41 Head: 0........................ : Ok Cyl: -41 Head: 1........................ : Ok Translator regeneration Regeneration method..................... : Use P-List only Translator regeneration error - Device Error Detected: "VSCE PERM OVL NOT LOADED" --------------------------------------------------------------------------------- On comparison to an identical drive, there is a slight difference in startup sound. It is pretty subtle but the good drive seems to have 3 different phases ... spin up, head move then track seek. The patient has similar noise with a weaker third stage. --------------------------------------------------------------------------------- Below is the drive id listing. There are differences in the "logical cylider count" and "current logical parameters" between the bad drive and an identical good drive. HDD parameters-BAD DRIVE CONFIGURATION GENERAL INFORMATION: ATA device Fixed device and/or controller Logical cylinders count..................................... 24071 Logical sectors per track................................... 63 Logical heads count......................................... 16 Model............................................. .......... WDC ROM MODEL--SABRE-- Serial number............................................ ... WDC-ROM SN# XYZ---- Firmware.......................................... .......... 05.01C05 Maximal block size for READ/WRITE MULTIPLE commands......... 16 Features Stop Timer Value IORDY............................................. Supported LBA Mode.......................................... Supported DMA Mode.......................................... Supported Current Logical Parameters Cylinders......................................... 24 071 Heads............................................. 16 Sectors........................................... 63 Capacity.......................................... 24 263 568 Sectors (11 847.4 Mb) Capacity available in LBA Mode.................... 156 383 137 Sectors (76 359 Mb) Capacity available in LBA 48 Mode................. 156 383 137 Sectors (76 359 Mb) Available DMA Mode Multiword DMA Mode 0 Multiword DMA Mode 1 Multiword DMA Mode 2 Active DMA Mode............................................. Multiword DMA Mode 2 Active UDMA/33 modes Ultra DMA/33 Mode 0 Ultra DMA/33 Mode 1 Ultra DMA/33 Mode 2 Ultra DMA/33 Mode 3 Ultra DMA/33 Mode 4 Ultra DMA/33 Mode 5 Current UDMA/33 mode........................................ [none] Current PIO mode Supported Enhanced PIO Modes PIO MODE 3 PIO MODE 4 Minimal multiword DMA cycle time............................ 120 ns Recommended multiword DMA cycle time........................ 120 ns Minimal multiword PIO cycle time w/o stream control......... 120 ns Minimal multiword PIO cycle time with IORDY................. 120 ns Supported standards ATA - 3 ATA - 4 ATA - 5 ATA - 6 Supported Command Sets S.M.A.R.T functions Security system............................................ . Not supported condition flags : password set...................................... NO HDD Locked........................................ NO HDD Frozen........................................ NO wrong password count exceeded..................... NO security erase support............................ NO security level.................................... HIGH Master code.............................................. ... 0000 HDD parameters- GOOD (DONER) DRIVE CONFIGURATION GENERAL INFORMATION: ATA device Fixed device and/or controller Logical cylinders count..................................... 16383 Logical sectors per track................................... 63 Logical heads count......................................... 16 Model............................................. .......... WDC WD800BB-00JHC0 Serial number............................................ ... WD-WMAM97734248 Firmware.......................................... .......... 05.01C05 Maximal block size for READ/WRITE MULTIPLE commands......... 16 Features Stop Timer Value IORDY............................................. Supported LBA Mode.......................................... Supported DMA Mode.......................................... Supported Current Logical Parameters Cylinders......................................... 16 383 Heads............................................. 16 Sectors........................................... 63 Capacity.......................................... 16 514 064 Sectors (8 063.5 Mb) Capacity available in LBA Mode.................... 156 301 488 Sectors (76 319.1 Mb) Capacity available in LBA 48 Mode................. 156 301 488 Sectors (76 319.1 Mb) Available DMA Mode Multiword DMA Mode 0 Multiword DMA Mode 1 Multiword DMA Mode 2 Active DMA Mode............................................. Multiword DMA Mode 2 Active UDMA/33 modes Ultra DMA/33 Mode 0 Ultra DMA/33 Mode 1 Ultra DMA/33 Mode 2 Ultra DMA/33 Mode 3 Ultra DMA/33 Mode 4 Ultra DMA/33 Mode 5 Current UDMA/33 mode........................................ [none] Current PIO mode Supported Enhanced PIO Modes PIO MODE 3 PIO MODE 4 Minimal multiword DMA cycle time............................ 120 ns Recommended multiword DMA cycle time........................ 120 ns Minimal multiword PIO cycle time w/o stream control......... 120 ns Minimal multiword PIO cycle time with IORDY................. 120 ns Supported standards ATA - 3 ATA - 4 ATA - 5 ATA - 6 Supported Command Sets S.M.A.R.T functions Security control Security system............................................ . Supported condition flags : password set...................................... NO HDD Locked........................................ NO HDD Frozen........................................ NO wrong password count exceeded..................... NO security erase support............................ NO security level.................................... HIGH Master code.............................................. ... FFFE Thanks Gordon |
| Author: | N.C. [ October 27th, 2009, 6:41 ] |
| Post subject: | Re: WD800BB-00JHC0 id'd as Sabre but tests ok (mostly). |
try to use loader |
| Author: | gbulger [ October 27th, 2009, 8:32 ] |
There doesn't seem to be a loader create feature in PC3K. Where else could I get a loader fro this drive? Thanks |
| Author: | N.C. [ October 27th, 2009, 8:47 ] |
mod 11 |
| Author: | pepe [ October 28th, 2009, 18:11 ] |
kinda RTFM... |
