HDD GURU FORUMS
http://forum.hddguru.com/
Maxtor 4R120L0
http://forum.hddguru.com/viewtopic.php?f=11&t=13787
Page 1 of 1
Author:  lcoughey [ October 30th, 2009, 8:35 ]
Post subject:  Maxtor 4R120L0
I'm looking for a LDR for this drive:
Model: 4R120L0
Code: RAMB1TU0
If you can help, it would be appreciated.
Thanks,
Author:  dobrevjetser [ October 30th, 2009, 8:47 ]
Post subject:  Re: Maxtor 4R120L0
Here i have one for an 160G drive.
Should work also.
Dobre
Maxtor 4R160L0 RAMB1TU0-8240-R415B2LE.rar [1.08 MiB]
Downloaded 617 times
Author:  lcoughey [ October 30th, 2009, 8:48 ]
Thanks,
Will give it a try in a couple of minutes.
Author:  lcoughey [ October 30th, 2009, 9:13 ]
Doh! Anyone got the PC3000UDMA LDR file for this drive?
Author:  dobrevjetser [ October 30th, 2009, 9:32 ]
Not working ?
Dobre
Author:  lcoughey [ October 30th, 2009, 9:37 ]
I renamed it from .pcr to .ldr, but it does not work.
LDR does not contain overlay 1B
Author:  dobrevjetser [ October 30th, 2009, 9:41 ]
NO, the pcr file has to be loaded in the UDMA database !
Open the database, choose import and select the pcr file.
:D
Dobre
Author:  lcoughey [ October 30th, 2009, 9:46 ]
Good point...it has been so long since I've imported into the database, I forgot it even existed. Thanks for the wake up call.
Author:  lcoughey [ October 30th, 2009, 9:51 ]
Yup, that worked better and helped me confirm that the problems are internal. Now it is time for a visual inspection...I suspect that it is toast.
Author:  dobrevjetser [ October 30th, 2009, 9:59 ]
Glad this worked. :)
You dont happen to have a loader for a Athena DSP 20B020H1 with code WAK21R90?
Dobre
Author:  lcoughey [ October 30th, 2009, 11:03 ]
Sorry...I don't have that one here. I'll get someone to check and see if we have a drive from which we can make a LDR for you.
Author:  ccamargol [ December 1st, 2009, 18:17 ]
it is for PC3000 PCI OR UDMA?
Author:  dobrevjetser [ December 2nd, 2009, 4:12 ]
Thanks Ccamargol, but this case has been solved in the mean time :)
Dobre
http://www.phpbb.com/
