Page 1 of 1
HD501LJ
Posted: November 4th, 2009, 13:26
by zebong
Hi to all,
Have this in Samsung terminal, First Problem was TVS.
SPW 1.5G LinkOk! ADC: FFFE
SpnOk
spd: 0000 0000 0000
H: +00000
ADC: FFFF
DAC: 537E
Unlatch Tk: 000174DC
Unlatch Done
ENG>SRV>
SvoTbl Loaded
BD
-Tout-Tout-Tout-Tout-Tout-Tout-Tout-Tout-Tout-Tout-Tout-Tout-Tout-Tout-Tout-Tout-Tout-Tout-Tout-Tout
Any sugestion
ZeBong
Re: HD501LJ
Posted: November 5th, 2009, 3:57
by dobrevjetser
Last time i got this drive had bad heads.
Bad module A3 HSC_CYL or module 0D GEO_TBL gives same symptoms.
dobre
Re: HD501LJ
Posted: November 5th, 2009, 4:08
by N.C.
If the TVS was triggered, than there was some overvoltage.
Overvoltage can lightly damage anything, including preamp and even heads as well.
But anyway, this termlog not looks like fatal problem.
Can you read LBA after soft reset?
Janos
Re: HD501LJ
Posted: November 5th, 2009, 7:06
by hddguy
Does the drive reach DSC and DRDY?
Re: HD501LJ
Posted: November 5th, 2009, 12:30
by zebong
Thanks to all,
Afther a soft reset i can get DRD DSC, nothing more.
if i use other PCB i can not get the serial, it have some adapt. info in the pcb.
The disk was used to copy files from a pc to other.
It can happen that it take a little "drop" not much.
I will try to change heads to see what i can get.
Thanks Again
ZeBong
Re: HD501LJ
Posted: November 5th, 2009, 14:33
by zebong
After change heads i had this in terminal :
SPW 1.5G LinkOk! ADC: FFFF
SpnOk
spd: 0000 0000 0000
H: +00000
ADC: FFFF
DAC: 537E
Unlatch Tk: 000149DB
Unlatch Done
ENG>SRV>Tgt Tk:00000000 Hd:00 SkRetryCnt:+00000
AP_TO
C: 000005DC H: +00000
Unlatch Tk: 0000F839
Unlatch Done
SvoTbl Loaded
H: +00000
Unlatch Tk: 00014BF4
Unlatch Done
H: +00000
Unlatch Tk: 00014A75
Unlatch Done
H: +00000
Unlatch Tk: 00014DC2
Unlatch Done
H: +00000
Unlatch Tk: 00014F4B
Unlatch Done
H: +00000
Unlatch Tk: 000151FA
Unlatch Done
_#E/;øEYRTWOd
Ö o R ê k j @ : V = Á Î o X I 4 Ø \ ) ö
ppÐà P`pÀà PppÐà PppÀà PppÐà PppÀà P=Í;8IßÇs5Ðì2h,Û
7"_3àþÔ÷;,x8ÓÌ):Àò8,=õÎp:iÅc89Îp6û\4Ô÷;,x8ÓÌ):Àò8,=õÎp:iÅc89Îp6û\4Ô÷;,x8ÓÌ):Àò8,=õÎp:iÅc89Îp6û\4Ô÷;,x8ÓÌ):Àò8,=õÎp:iÅc89Îp6û\4Ô÷;,x8ÓÌ)=Í;8IßÇs5Ðì2h,Û
7"_3àþÔ÷;,x8ÓÌ)=ú;5GÇs6(É43Ù1Ö/g÷ÞÓ9Í+7ÔÎp9Áò7H<Ð9sÆY7-8\Ð3û17Û ;,x8ÓÌ)9Áò7H<Ð9sÆY7-8\Ð3û17Û ;,x8ÓÌ)9Áò7H<Ð9sÆY7-8\Ð3û17Û ;,x8ÓÌ)CQuILqILqILqILqCQu BF
AP_TO
C: 00000600 H: +00002
AP_FSAM
C: 000100A9 H: +00002
UF 6 GrayFailErr
H: +00001
Unlatch Tk: 00015892
Unlatch Done
AP_TO
Unlatch Tk: 000283C4
Unlatch Done
AP_TO
AP_FSAM
C: 0000DB3D H: +00000
UF 6 GrayFailErr
H: +00001
Unlatch Tk: 0001617B
Unlatch Done
Tgt Tk:00000002 Hd:00 SkRetryCnt:+00000
AP_TO
C: 000005EA H: +00000
UF 4 1stVelErr
H: +00001
Unlatch Tk: 000163C7
Unlatch Done
AP_TO
UF 3 1stGrayErr
H: +00001
Unlatch Tk: 00016623
Unlatch Done
WriteSctLog -- buffer not valid
LED 14 0000
SRST
Them put the heads back in the donor disk and now have this :
SPW 1.5G LinkOk! ADC: 0003
SpnOk
spd: 0000 0000 0000
H: +00000
ADC: 0003
DAC: 6B85
Unlatch Tk: 000188DB
Unlatch Done
ENG>SRV>
SvoTbl Loaded
H: +00000
Unlatch Tk: 00015F2B
Unlatch Done
ppÀà0=Í;8IßÇs5Ðì2h,Û 7"_3àþÔ÷;,x8ÓÌ):Àò8,=õÎp:iÅc89Îp6û\4Ô÷;,x8ÓÌ):Àò8,=õÎp:iÅc89Îp6û\4Ô÷;,x8ÓÌ):Àò8,=õÎp:iÅc89Îp6û\4Ô÷;,x8ÓÌ):Àò8,=õÎp:iÅc89Îp6û\4Ô÷;,x8ÓÌ)=Í;8IßÇs5Ðì2h,Û 7"_3àþÔ÷;,x8ÓÌ)=ú;5GÇs6(É43Ù1Ö/g÷ÞÓ9Í+7ÔÎp9Áò7H<Ð9sÆY7-8\Ð3û17Û ;,x8ÓÌ)9Áò7H<Ð9sÆY7-8\Ð3û17Û ;,x8ÓÌ)9Áò7H<Ð9sÆY7-8\Ð3û17Û ;,x8ÓÌ)CQuILqILqILqILqCQu H: +00000
Unlatch Tk: 00015EC4
Unlatch Done
Unlatch Tk: 000197A3
Unlatch Done
Unlatch Tk: 00019929
Unlatch Done
ppÀà0=Í;8IßÇs5Ðì2h,Û 7"_3àþÔ÷;,x8ÓÌ):Àò8,=õÎp:iÅc89Îp6û\4Ô÷;,x8ÓÌ):Àò8,=õÎp:iÅc89Îp6û\4Ô÷;,x8ÓÌ):Àò8,=õÎp:iÅc89Îp6û\4Ô÷;,x8ÓÌ):Àò8,=õÎp:iÅc89Îp6û\4Ô÷;,x8ÓÌ)=Í;8IßÇs5Ðì2h,Û 7"_3àþÔ÷;,x8ÓÌ)=ú;5GÇs6(É43Ù1Ö/g÷ÞÓ9Í+7ÔÎp9Áò7H<Ð9sÆY7-8\Ð3û17Û ;,x8ÓÌ)9Áò7H<Ð9sÆY7-8\Ð3û17Û ;,x8ÓÌ)9Áò7H<Ð9sÆY7-8\Ð3û17Û ;,x8ÓÌ)CQuILqILqILqILqCQu5Ðì2h,Û 7"_3àþÔ÷;,x8ÓÌ):Àò8,=õÎp:iÅc89Îp6û\4Ô÷;,x8ÓÌ):Àò8,=õÎp:iÅc89Îp6û\4Ô÷;,x8ÓÌ):Àò8,=õÎp:iÅc89Îp6û\4Ô÷;,x8ÓÌ):Àò8,=õÎp:iÅc89Îp6û\4Ô÷;,x8ÓÌ)=Í;8IßÇs5Ðì2h,Û 7"_3àþÔ÷;,x8ÓÌ)=ú;5GÇs6(É43Ù1Ö/g÷ÞÓ9Í+7ÔÎp9Áò7H<Ð9sÆY7-8\Ð3û17Û ;,x8ÓÌ)9Áò7H<Ð9sÆY7-8\Ð3û17Û ;,x8ÓÌ)9Áò7H<Ð9sÆY7-8\Ð3û17Û ;,x8ÓÌ)CQuILqILqILqILqCQu BF
AP_TO
C: 00000616 H: +00002
UF 4 1stVelErr
H: +00001
Unlatch Tk: 00014A81
Unlatch Done
Sb
LED 14 0000
LED 14 0000
I think the heads are gone.
Re: HD501LJ
Posted: November 5th, 2009, 14:49
by N.C.
yes, heads are gone....
Re: HD501LJ
Posted: November 5th, 2009, 14:55
by zebong
N.C. wrote:yes, heads are gone....
no the heads are back again, i forget the screw of the heads.
this looks like a message of alignment !!!
Re: HD501LJ
Posted: November 5th, 2009, 15:20
by zebong
The heads are working in the donor disk:
SPW 1.5G LinkOk! ADC: 0002
SpnOk
spd: 0000 0000 FFFF
H: +00000
ADC: 0003
DAC: 6B85
Unlatch Tk: 0001640F
Unlatch Done
ENG>SRV>
SvoTbl Loaded
BD
I=0000E100, T=0005
000F
000D
0015
0012
0011
0014
000A
0009
000A
0014
0010
0011
0013
000C
000D
0014
0011
0016ENG>
The only different that i notice is the date:
P - 2008.02
D - 2007.07 :(
Re: HD501LJ
Posted: November 5th, 2009, 15:54
by N.C.
I have a problem with you:
The data recovery needs exteme precision!
You working too hurry but not precise!
You can easily kill drive and render to unrecoverable with similar mistakes....
This is not good anyway.
Janos
