 Post subject: WD 10EAVS-00D7B1
PostPosted: November 7th, 2009, 10:01
Good Day
i have WD10EAVS-00D7B1 it's showing 0MB space and in kernel mode and not detecting Drive Model when i tried to change RAM Head Map Error Accord NO HEAD MAP found
Techno mode key
Techno mode key......................... : Ok
ROM:
Flash Dir reading....................... : Ok
ROM reading............................. : Ok
ROM Data size........................... : 192 Kb
ROM version............................. : 05.CEE
ROM generation.......................... : 05.CEE
Link table version...................... : 04.3F.
Heads number............................ : 6
Heads number in use..................... : 6
Switched off heads...................... : No
Head map................................ : 2,3,4,5,6,7
Firmware version........................ : 000500CE
0 0
1 0
2 0
3 0
4 0
5 0
Map has incorrect bytes
Kermit
Offset (hex): 4000000
Map Size: 8
\x06\x02\x03\x04\x05\x06\x07\x00\x00
\x06\x00\x02\x03\x04\x05\x06\x07\x00\x00
If you face same problem please let me know Thanks.
 Post subject: Re: WD 10EAVS-00D7B1
PostPosted: November 7th, 2009, 10:29
I sent you a PM.
PostPosted: November 9th, 2009, 5:19
Hi Luke
any chance you could pm me with the info also as I hace the same issues with a drive
will be greatly appreciated.
Thankyou
PostPosted: November 12th, 2009, 5:52
I believe this problem could be associated with unstable motor rotation.
