| WD 10EAVS-00D7B1 http://forum.hddguru.com/viewtopic.php?f=11&t=13861 |
Page 1 of 1 |
| Author: | itconcept [ November 7th, 2009, 10:01 ] |
| Post subject: | WD 10EAVS-00D7B1 |
Good Day i have WD10EAVS-00D7B1 it's showing 0MB space and in kernel mode and not detecting Drive Model when i tried to change RAM Head Map Error Accord NO HEAD MAP found Techno mode key Techno mode key......................... : Ok ROM: Flash Dir reading....................... : Ok ROM reading............................. : Ok ROM Data size........................... : 192 Kb ROM version............................. : 05.CEE ROM generation.......................... : 05.CEE Link table version...................... : 04.3F. Heads configuration..................... : by map Heads number............................ : 6 Heads number in use..................... : 6 Switched off heads...................... : No Head map................................ : 2,3,4,5,6,7 Firmware version........................ : 000500CE 0 0 1 0 2 0 3 0 4 0 5 0 Map has incorrect bytes Kermit Offset (hex): 4000000 Size: 100000 Map Size: 8 ================================== \x06\x02\x03\x04\x05\x06\x07\x00\x00 \x06\x00\x02\x03\x04\x05\x06\x07\x00\x00 If you face same problem please let me know Thanks. |
| Author: | lcoughey [ November 7th, 2009, 10:29 ] |
| Post subject: | Re: WD 10EAVS-00D7B1 |
I sent you a PM. |
| Author: | crecomp [ November 9th, 2009, 5:19 ] |
Hi Luke any chance you could pm me with the info also as I hace the same issues with a drive will be greatly appreciated. Thankyou |
| Author: | hddguy [ November 12th, 2009, 5:52 ] |
I believe this problem could be associated with unstable motor rotation. |
