 Post subject: Deepspar Disk Imager - Timeout while waiting for DMA to writ
PostPosted: November 12th, 2009, 10:10
Hi
I am having problems imaging using DDI. THe DDI can detect both source
and destination drives. But when Start Imaging I see Initializing LBA
Map followed by Timeout while waiting for DMA to write sectors. I
suspected some problem with destination drive. I replaced with
different destination drives, all came up with same error.
Anyone came across this problem before?. DDI Imaging settings are
default.
Thank You
Cheers
-Jag
 Post subject: Re: Deepspar Disk Imager - Timeout while waiting for DMA to writ
PostPosted: November 12th, 2009, 13:25
I suggest you post your question on the DeepSpar forums. They are usually fast at responding and they'd be the best people to answer your questions.
PostPosted: November 13th, 2009, 5:27
Strange error...
Vitaliy Mokosiy
CTO, Atola Technology
Maker of MultiDrive
PostPosted: November 13th, 2009, 14:01
Are you using the supplied/recommended mainboard?
And also the modified IDE cable?
