| Deepspar Disk Imager - Timeout while waiting for DMA to writ http://forum.hddguru.com/viewtopic.php?f=11&t=13908 |
Page 1 of 1 |
| Author: | jag17 [ November 12th, 2009, 10:10 ] |
| Post subject: | Deepspar Disk Imager - Timeout while waiting for DMA to writ |
Hi I am having problems imaging using DDI. THe DDI can detect both source and destination drives. But when Start Imaging I see Initializing LBA Map followed by Timeout while waiting for DMA to write sectors. I suspected some problem with destination drive. I replaced with different destination drives, all came up with same error. Anyone came across this problem before?. DDI Imaging settings are default. Thank You Cheers -Jag |
| Author: | lcoughey [ November 12th, 2009, 13:25 ] |
| Post subject: | Re: Deepspar Disk Imager - Timeout while waiting for DMA to writ |
I suggest you post your question on the DeepSpar forums. They are usually fast at responding and they'd be the best people to answer your questions. |
| Author: | Vitaliy Mokosiy [ November 13th, 2009, 5:27 ] |
Strange error... |
| Author: | pcimage [ November 13th, 2009, 14:01 ] |
Are you using the supplied/recommended mainboard? And also the modified IDE cable? |
