 Post subject: Head Swap ST9160827AS
PostPosted: December 22nd, 2009, 5:24
Good Day
i have Seagate ST9160827AS 2.5 laptop HDD it shows $$$ sign in Terminal i opened it i found Heads are Damage i swapped Head with same Model,Side code and F/w Donor still it is showing BSY status and in Terminal showing $$sign with some codes i swapped this Head again to Donor now Donor also not detecting same Error i am getting in Terminals if any comments please let me know Thanks.
 Post subject: Re: Head Swap ST9160827AS
PostPosted: December 22nd, 2009, 9:18
probably media-damage which destroyed good heads also.
Dobre
Murphy was an optimist
PostPosted: December 22nd, 2009, 9:27
This is why should professionals handle the phisical damaged cases....
Janos
PostPosted: December 23rd, 2009, 3:04
Good Day
it has 2 Platters without scratch any thing platters seems to be good any other reason why head gone bad and i am also Professional like u Thanks.
PostPosted: December 23rd, 2009, 8:43
microscopic damages, not visible by the eye.
Dobre
PostPosted: December 31st, 2009, 13:46
Or bad head change procedures...
PostPosted: January 2nd, 2010, 2:38
Good Day
HDDGuy Head Swap Procedure is Perfect i did lot of Head Swaps and i got success.
PostPosted: January 2nd, 2010, 7:31
Good Day
Are You By Any Chance Amarbir S. Dillon ? :D
PostPosted: January 2nd, 2010, 10:06
itconcept wrote:
Good Day
I don't want to say nothing. :mrgreen:
