| Head Swap ST9160827AS http://forum.hddguru.com/viewtopic.php?f=11&t=14301 |
Page 1 of 1 |
| Author: | itconcept [ December 22nd, 2009, 5:24 ] |
| Post subject: | Head Swap ST9160827AS |
Good Day i have Seagate ST9160827AS 2.5 laptop HDD it shows $$$ sign in Terminal i opened it i found Heads are Damage i swapped Head with same Model,Side code and F/w Donor still it is showing BSY status and in Terminal showing $$sign with some codes i swapped this Head again to Donor now Donor also not detecting same Error i am getting in Terminals if any comments please let me know Thanks. |
| Author: | dobrevjetser [ December 22nd, 2009, 9:18 ] |
| Post subject: | Re: Head Swap ST9160827AS |
probably media-damage which destroyed good heads also. Dobre |
| Author: | N.C. [ December 22nd, 2009, 9:27 ] |
This is why should professionals handle the phisical damaged cases.... Janos |
| Author: | itconcept [ December 23rd, 2009, 3:04 ] |
Good Day it has 2 Platters without scratch any thing platters seems to be good any other reason why head gone bad and i am also Professional like u Thanks. |
| Author: | dobrevjetser [ December 23rd, 2009, 8:43 ] |
microscopic damages, not visible by the eye. Dobre |
| Author: | hddguy [ December 31st, 2009, 13:46 ] |
Or bad head change procedures... |
| Author: | itconcept [ January 2nd, 2010, 2:38 ] |
Good Day HDDGuy Head Swap Procedure is Perfect i did lot of Head Swaps and i got success. |
| Author: | HeadCrash [ January 2nd, 2010, 7:31 ] |
Good Day Are You By Any Chance Amarbir S. Dillon ? |
| Author: | N.C. [ January 2nd, 2010, 10:06 ] |
itconcept wrote: Good Day it has 2 Platters without scratch any thing platters seems to be good any other reason why head gone bad and i am also Professional like u Thanks. ... I don't want to say nothing. |
