 Post subject: Firmware download from USB drive without removing?
PostPosted: December 21st, 2009, 0:12
Hi probably a silly question, but you don't know till you ask.
Can I get the whole PC3000 compatible firmware et al from a USB drive and store it in my Database without removing the physical HDD from the USB case (2.5" and 3.5")?
Reason is, I am building my library up and want to get firmwares from all new drives passing through. We sell/return data on external USB drives and it would be good to be able to capture the firmware/modules without having to open the cases and plug in via SATA.
Can this be done? Can it be done directly on PC3000?
 Post subject: Re: Firmware download from USB drive without removing?
PostPosted: December 21st, 2009, 1:51
BadMac, the USB interfaces usually only support a limited subset of SCSI commands. The device then converts these into ATA commands. I haven't found one that doesn't. If you do find one, please post back here! I am pretty sure I am not the only person who would be interested.
Shawn
PostPosted: December 21st, 2009, 13:00
It is possible to write such a program for some USB boxes
PC3000 cannot do that
PostPosted: December 23rd, 2009, 0:44
Thanks Guys, maybe i'll try writing something over the holidays. If nothing else it will be an interesting learning experience.
Mark
PostPosted: December 28th, 2009, 20:08
Doomer: which adapter did you have in mind?
PostPosted: December 29th, 2009, 11:37
phishin_ca, easiest one would be Cypress based
PostPosted: December 29th, 2009, 19:40
Doomer, very cool! Thanks
Users browsing this forum: No registered users and 48 guests
