Seagate ST9320320AS (Momentus 5400.5 - F3 Family) locked
Posted: January 14th, 2010, 5:27
Hi to all.
I have a Seagate ST9320320AS (Momentus 5400.5 - F3 Family), with master password setted.
When i run Pc3K Seagate F3 Utility, it say me "Attention! Secutity-Locked Hdd"
I try to use the option "Clear Password" and i have a windows with the follow message"To remove the password you have to reform the command "Open-HDD""
I try with the command "Open-HDD" but Master and User password, are all to "00" Hex.
With common Seagate 7200.11 (F3 Family), i can remove password using solution for Lock LED.
I try to use the same solution for ST9330320AS, but the solution end with an error, and password remain setted.
Someone know the correct way for see the setted password or to remove it ?
Please for me is very important and urgent. An your help will be apreciated.
Thank you.
Thank you.
