| Pending bug - problem with 2 disks http://forum.hddguru.com/viewtopic.php?f=11&t=14588 |
Page 1 of 1 |
| Author: | arvika [ January 20th, 2010, 19:42 ] |
| Post subject: | Pending bug - problem with 2 disks |
I have two disk with similar problem called "pending bug" i suppose.. 1. Seagate Barracuda 7200.10 3,5" ST3250410AS I read the http://www.acelaboratory.com/forum/view ... 05240ce62e I try this, but something is wrong. Log: Test : HDD initialization by utility... Switch HDD PWR supply.... : No Terminal Reset........... : Yes Terminal work speed...... : 9600 Used LDR................. : C:\Program Files\ACE Lab\PC-3000\Bin\!Profiles\SeagateBara\Barracuda 7200.10 NHawk Plus\ST3250410AS-4.AAA-6RYKBGFQ\Data\LDR\SgLDR.ldr Loaded from.............. : G:\PC3K\NewTask2\LDR\SgLDR_Init.ldr Work with HDD through.... : ATA App...................... : Loading from LDR Used modifications....... : Fix 'Pending Bug', Fix 'Pending Bug' (fix 2), Fix 'Not Handled Soft Path' Bug Load Ovl 0............... : No Initializing Safe Mode... Switching HDD power supply OFF Switching HDD power supply ON HDD SpinUp.............................. : Ok Reading boot SA elements... Reading boot adaptives.................. : Ok Reading Reserve track defect list....... : Ok App patching... Downloading App code... App code downloading.................... : Ok Starting App code... cmd 2A, params 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 (P ) Buzz HM SFI ! cmd Drive is not ready Starting App code....................... : Ok Cannot start App! Cannot start App! Can You help me with this? 2. Seagate Momentus 5400.4 2,5" ST9250827AS This disk is not supported by PC3K UDMA right? It is possible to use "pending bug" anyway? I try but it don't work too. Similar effect. Maybe somewhere i made a mistake? Any ideas? |
| Author: | rameez [ January 22nd, 2010, 3:42 ] |
| Post subject: | Re: Pending bug - problem with 2 disks |
There could be matching issues with the loader that you have . |
| Author: | hddguy [ January 22nd, 2010, 6:20 ] |
Maybe problems with heads/bad media also. I think DSC and DRDY is possible after long wait. Where did you get LDR from? Was from a donor drive? |
| Author: | arvika [ January 22nd, 2010, 8:38 ] |
I read LDR directly from the patient disks. It takes a little bit long, but it read correctly. |
