 Post subject: Hawk WD1600JS No access to data
PostPosted: January 20th, 2010, 20:01
Heads test pass ok. If I try and access data it produces ABR on every LBA. Translator regeneration fails.
Techno mode key
Techno mode key......................... : Ok
RAM:
Zone allocation table................... : Ok
Cyl Count............................... : 83935
SA SPT.................................. : 720
Head number reading..................... : Ok
Heads number............................ : 4
ROM:
ROM reading............................. : Ok
ROM Data size........................... : 128 Kb
ROM version............................. : 10.8WE
ROM generation.......................... : 10.8WE
Link table version...................... : 02.8A.
Heads number in use..................... : 4
Switched off heads...................... : No
Head map................................ : 0,1,4,5
Firmware version........................ : 108W?
Service area:
SA dir reading.......................... : Ok (Copy 0)
Configuration reading................... : Ok
Master Password......................... : has not been set
User Password........................... : has not been set
SA structure test
Module 01 Copy 0........................ : Ok
Module 01 Copy 1........................ : Ok
Module 38 Copy 0........................ : Ok
Module reading error: Physical read error C/H/S: -1/1/174 - Device Error Detected: "DISK ECU UNSAFE ERROR"
Module 38 Copy 1........................ : Error
Module 17 Copy 0........................ : Ok
Module 17 Copy 1........................ : Ok
Module 15 Copy 0........................ : Ok
Module reading error: Physical read error C/H/S: -1/1/312 - Device Error Detected: "DISK ECU UNSAFE ERROR"
Module 15 Copy 1........................ : Error
Module 39 Copy 0........................ : Ok
Module reading error: Physical read error C/H/S: -1/1/344 - Device Error Detected: "DISK ECU UNSAFE ERROR"
Module 39 Copy 1........................ : Error
Module 2F Copy 0........................ : Ok
Module 2F Copy 1........................ : Ok
Module 50 Copy 0........................ : Ok
Module 50 Copy 1........................ : Ok
Module 62 Copy 0........................ : Ok
Module 62 Copy 1........................ : Ok
Module 35 Copy 0........................ : Ok
Module 35 Copy 1........................ : Ok
Module 02 Copy 0........................ : Ok
Module 02 Copy 1........................ : Ok
Module 33 Copy 0........................ : Ok
Module reading error: Physical read error C/H/S: -2/1/174 - Device Error Detected: "DISK ECU UNSAFE ERROR"
Module 33 Copy 1........................ : Error
Module 26 Copy 0........................ : Ok
Module reading error: Physical read error C/H/S: -2/1/527 - Device Error Detected: "DISK DAM ERROR"
Module 26 Copy 1........................ : Error
Module 28 Copy 0........................ : Ok
Module 28 Copy 1........................ : Ok
Module 2D Copy 0........................ : Ok
Module 2D Copy 1........................ : Ok
Module 1B Copy 0........................ : Ok
Module reading error: Physical read error C/H/S: -3/1/312 - Device Error Detected: "DISK DAM ERROR"
Module 1B Copy 1........................ : Error
Module 1C Copy 0........................ : Ok
Module 1C Copy 1........................ : Ok
Module 40 Copy 0........................ : Ok
Module 40 Copy 1........................ : Ok
Module 34 Copy 0........................ : Ok
Module reading error: Physical read error C/H/S: -3/1/464 - Device Error Detected: "DISK ECU UNSAFE ERROR"
Module 34 Copy 1........................ : Error
Module 29 Copy 0........................ : Ok
Module 29 Copy 1........................ : Ok
Module 51 Copy 0........................ : Ok
Module 51 Copy 1........................ : Ok
Module 2E Copy 0........................ : Ok
Module reading error: Physical read error C/H/S: -8/1/175 - Device Error Detected: "DISK ECU UNSAFE ERROR"
Module 2E Copy 1........................ : Error
Module reading error: Physical read error C/H/S: -8/0/294 - Device Error Detected: "DISK ECU UNSAFE ERROR"
Module 21 Copy 0........................ : Error
Module reading error: Physical read error C/H/S: -8/1/294 - Device Error Detected: "DISK ECU UNSAFE ERROR"
Module 21 Copy 1........................ : Error
Module 19 Copy 0........................ : Ok
Module 19 Copy 1........................ : Ok
Module 43 Copy 0........................ : Ok
Module 43 Copy 1........................ : Ok
Module 04 Copy 0........................ : Ok
Module 04 Copy 1........................ : Ok
Module 2A Copy 0........................ : Ok
Module 2A Copy 1........................ : Ok
Module 52 Copy 0........................ : Ok
Module 52 Copy 1........................ : Ok
Module 11 Copy 0........................ : Ok
Module reading error: Physical read error C/H/S: -9/1/175 - Device Error Detected: "DISK ECU UNSAFE ERROR"
Module 11 Copy 1........................ : Error
Module 24 Copy 0........................ : Ok
Module reading error: Physical read error C/H/S: -9/1/310 - Device Error Detected: "DISK ECU UNSAFE ERROR"
Module 24 Copy 1........................ : Error
Module 1E Copy 0........................ : Ok
Module 1E Copy 1........................ : Ok
Module 42 Copy 0........................ : Ok
Module 42 Copy 1........................ : Ok
Module 05 Copy 0........................ : Ok
Module 05 Copy 1........................ : Ok
Module 0C Copy 0........................ : Ok
Module 0C Copy 1........................ : Ok
Module 53 Copy 0........................ : Ok
Module 53 Copy 1........................ : Ok
Module 31 Copy 0........................ : Ok
Module 31 Copy 1........................ : Ok
Module 23 Copy 0........................ : Ok
Module reading error: Physical read error C/H/S: -10/1/310 - Device Error Detected: "DISK ECU UNSAFE ERROR"
Module 23 Copy 1........................ : Error
Module 61 Copy 0........................ : Ok
Module reading error: Physical read error C/H/S: -10/1/342 - Device Error Detected: "DISK ECU UNSAFE ERROR"
Module 61 Copy 1........................ : Error
Module 4C Copy 0........................ : Ok
Module 4C Copy 1........................ : Ok
Module 07 Copy 0........................ : Ok
Module 07 Copy 1........................ : Ok
Module 4A Copy 0........................ : Ok
Module 4A Copy 1........................ : Ok
Module 36 Copy 0........................ : Ok
Module 36 Copy 1........................ : Ok
Module 25 Copy 0........................ : Ok
Module reading error: Physical read error C/H/S: -11/1/175 - Device Error Detected: "DISK ECU UNSAFE ERROR"
Module 25 Copy 1........................ : Error
Module reading error: Physical read error C/H/S: -11/0/262 - Device Error Detected: "DISK ECU UNSAFE ERROR"
Module 22 Copy 0........................ : Error
Module reading error: Physical read error C/H/S: -11/1/262 - Device Error Detected: "DISK ECU UNSAFE ERROR"
Module 22 Copy 1........................ : Error
Module 32 Copy 0........................ : Ok
Module 32 Copy 1........................ : Ok
Module 41 Copy 0........................ : Ok
Module 41 Copy 1........................ : Ok
Module 06 Copy 0........................ : Ok
Module 06 Copy 1........................ : Ok
Module 49 Copy 0........................ : Ok
Module 49 Copy 1........................ : Ok
Module 37 Copy 0........................ : Ok
Module 37 Copy 1........................ : Ok
Module C4 Copy 0........................ : Ok
Module reading error: Physical read error C/H/S: -3/1/521 - Device Error Detected: "DISK ECU UNSAFE ERROR"
Module C4 Copy 1........................ : Error
Module C5 Copy 0........................ : Ok
Module C5 Copy 1........................ : Ok
Module CC Copy 0........................ : Ok
Module CC Copy 1........................ : Ok
Module CA Copy 0........................ : Ok
Module reading error: Physical read error C/H/S: -3/1/601 - Device Error Detected: "DISK ECU UNSAFE ERROR"
Module CA Copy 1........................ : Error
Module CB Copy 0........................ : Ok
Module CB Copy 1........................ : Ok
Module CD Copy 0........................ : Ok
Module CD Copy 1........................ : Ok
Module CF Copy 0........................ : Ok
Module CF Copy 1........................ : Ok
Module CE Copy 0........................ : Ok
Module CE Copy 1........................ : Ok
Module 91 Copy 0........................ : Ok
Module 91 Copy 1........................ : Ok
Module 92 Copy 0........................ : Ok
Module 92 Copy 1........................ : Ok
Module 93 Copy 0........................ : Ok
Module 93 Copy 1........................ : Ok
Module C1 Copy 0........................ : Ok
Module C1 Copy 1........................ : Ok
Module C2 Copy 0........................ : Ok
Module C2 Copy 1........................ : Ok
Module C7 Copy 0........................ : Ok
Module C7 Copy 1........................ : Ok
Module 9E Copy 0........................ : Ok
Module 9E Copy 1........................ : Ok
Module B1 Copy 0........................ : Ok
Module B1 Copy 1........................ : Ok
Module E0 Copy 0........................ : Ok
Module reading error: Physical read error C/H/S: -6/1/179 - Device Error Detected: "DISK ECU UNSAFE ERROR"
Module E0 Copy 1........................ : Error
Module E8 Copy 0........................ : Ok
Module reading error: Physical read error C/H/S: -7/1/175 - Device Error Detected: "DISK ECU UNSAFE ERROR"
Module E8 Copy 1........................ : Error
Module FE Copy 0........................ : Ok
Module reading error: Physical read error C/H/S: -10/1/465 - Device Error Detected: "DISK ECU UNSAFE ERROR"
Module FE Copy 1........................ : Error
Module B6 Copy 0........................ : Ok
Module reading error: Physical read error C/H/S: -7/1/522 - Device Error Detected: "DISK ECU UNSAFE ERROR"
Module B6 Copy 1........................ : Error
Module B7 Copy 0........................ : Ok
Module B7 Copy 1........................ : Ok
Module D5 Copy 0........................ : Ok
Module reading error: Physical read error C/H/S: -9/1/465 - Device Error Detected: "DISK ECU UNSAFE ERROR"
Module D5 Copy 1........................ : Error
Module DA Copy 0........................ : Ok
Module reading error: Physical read error C/H/S: -8/1/465 - Device Error Detected: "DISK ECU UNSAFE ERROR"
Module DA Copy 1........................ : Error
Module DB Copy 0........................ : Ok
Module reading error: Physical read error C/H/S: -11/1/465 - Device Error Detected: "DISK ECU UNSAFE ERROR"
Module DB Copy 1........................ : Error
Module DF Copy 0........................ : Ok
Module DF Copy 1........................ : Ok
Module DD Copy 0........................ : Ok
Module reading error: Physical read error C/H/S: -12/1/175 - Device Error Detected: "DISK ECU UNSAFE ERROR"
Module DD Copy 1........................ : Error
Module D6 Copy 0........................ : Ok
Module reading error: Physical read error C/H/S: -12/1/204 - Device Error Detected: "DISK ECU UNSAFE ERROR"
Module D6 Copy 1........................ : Error
Module D7 Copy 0........................ : Ok
Module reading error: Physical read error C/H/S: -12/1/310 - Device Error Detected: "DISK ECU UNSAFE ERROR"
Module D7 Copy 1........................ : Error
Module D2 Copy 0........................ : Ok
Module D2 Copy 1........................ : Ok
Module BB Copy 0........................ : Ok
Module reading error: Physical read error C/H/S: -12/1/465 - Device Error Detected: "DISK ECU UNSAFE ERROR"
Module BB Copy 1........................ : Error
Module D9 Copy 0........................ : Ok
Module D9 Copy 1........................ : Ok
Module D4 Copy 0........................ : Ok
Module D4 Copy 1........................ : Ok
Module DC Copy 0........................ : Ok
Module reading error: Physical read error C/H/S: -13/1/176 - Device Error Detected: "DISK DAM ERROR"
Module DC Copy 1........................ : Error
Module D0 Copy 0........................ : Ok
Module D0 Copy 1........................ : Ok
Module D3 Copy 0........................ : Ok
Module reading error: Physical read error C/H/S: -13/1/310 - Device Error Detected: "DISK ECU UNSAFE ERROR"
Module D3 Copy 1........................ : Error
Module BA Copy 0........................ : Ok
Module BA Copy 1........................ : Ok
Module B9 Copy 0........................ : Ok
Module reading error: Physical read error C/H/S: -13/1/466 - Device Error Detected: "DISK DAM ERROR"
Module B9 Copy 1........................ : Error
Module BC Copy 0........................ : Ok
Module BC Copy 1........................ : Ok
Module D8 Copy 0........................ : Ok
Module D8 Copy 1........................ : Ok
Module FD Copy 0........................ : Ok
Module reading error: Physical read error C/H/S: -11/1/522 - Device Error Detected: "DISK ECU UNSAFE ERROR"
Module FD Copy 1........................ : Error
Module FB Copy 0........................ : Ok
Module reading error: Physical read error C/H/S: -6/1/522 - Device Error Detected: "DISK DAM ERROR"
Module FB Copy 1........................ : Error
Module E6 Copy 0........................ : Ok
Module reading error: Physical read error C/H/S: -13/1/523 - Device Error Detected: "DISK ECU UNSAFE ERROR"
Module E6 Copy 1........................ : Error
Module E7 Copy 0........................ : Ok
Module E7 Copy 1........................ : Ok
Module BE Copy 0........................ : Ok
Module BE Copy 1........................ : Ok
Module B8 Copy 0........................ : Ok
Module B8 Copy 1........................ : Ok
Module BF Copy 0........................ : Ok
Module BF Copy 1........................ : Ok
Module FC Copy 0........................ : Ok
Module FC Copy 1........................ : Ok
Module EE Copy 0........................ : Ok
Module EE Copy 1........................ : Ok
Module E1 Copy 0........................ : Ok
Module reading error: Physical read error C/H/S: -33/1/183 - Device Error Detected: "DISK ECU UNSAFE ERROR"
Module E1 Copy 1........................ : Error
Module E2 Copy 0........................ : Ok
Module reading error: Physical read error C/H/S: -34/1/179 - Device Error Detected: "DISK ECU UNSAFE ERROR"
Module E2 Copy 1........................ : Error
Module E3 Copy 0........................ : Ok
Module reading error: Physical read error C/H/S: -35/1/179 - Device Error Detected: "DISK ECU UNSAFE ERROR"
Module E3 Copy 1........................ : Error
Module E4 Copy 0........................ : Ok
Module reading error: Physical read error C/H/S: -36/1/179 - Device Error Detected: "DISK ECU UNSAFE ERROR"
Module E4 Copy 1........................ : Error
Module E5 Copy 0........................ : Ok
Module reading error: Physical read error C/H/S: -37/1/179 - Device Error Detected: "DISK ECU UNSAFE ERROR"
Module E5 Copy 1........................ : Error
Module E9 Copy 0........................ : Ok
Module reading error: Physical read error C/H/S: -38/1/179 - Device Error Detected: "DISK ECU UNSAFE ERROR"
Module E9 Copy 1........................ : Error
Module EA Copy 0........................ : Ok
Module reading error: Physical read error C/H/S: -39/1/184 - Device Error Detected: "DISK ECU UNSAFE ERROR"
Module EA Copy 1........................ : Error
Module EB Copy 0........................ : Ok
Module reading error: Physical read error C/H/S: -40/1/180 - Device Error Detected: "DISK ECU UNSAFE ERROR"
Module EB Copy 1........................ : Error
Module EC Copy 0........................ : Ok
Module reading error: Physical read error C/H/S: -41/1/180 - Device Error Detected: "DISK ECU UNSAFE ERROR"
Module EC Copy 1........................ : Error
Module ED Copy 0........................ : Ok
Module reading error: Physical read error C/H/S: -42/1/180 - Device Error Detected: "DISK ECU UNSAFE ERROR"
Module ED Copy 1........................ : Error
Module DE Copy 0........................ : Ok
Module reading error: Physical read error C/H/S: -14/1/176 - Device Error Detected: "DISK ECU UNSAFE ERROR"
Module DE Copy 1........................ : Error
Module FA Copy 0........................ : Ok
Module reading error: Physical read error C/H/S: -14/1/315 - Device Error Detected: "DISK ECU UNSAFE ERROR"
Module FA Copy 1........................ : Error
Defect list header has not been read
P-List reading.......................... : Ok
G-List reading.......................... : Ok
HDD parameters
CONFIGURATION GENERAL INFORMATION:
ATA device
Fixed device and/or controller
Logical cylinders count..................................... 16383
Logical sectors per track................................... 63
Logical heads count......................................... 16
Model....................................................... WDC WD1600JS-75NCB1
Serial number............................................... WD-WMANM1689775
Firmware.................................................... 10.02E01
Maximal block size for READ/WRITE MULTIPLE commands......... 16
Features
Stop Timer Value
IORDY............................................. Supported
LBA Mode.......................................... Supported
DMA Mode.......................................... Supported
Current Logical Parameters
Cylinders......................................... 16 383
Heads............................................. 16
Sectors........................................... 63
Capacity.......................................... 16 514 064 Sectors (8 063.5 Mb)
Capacity available in LBA Mode.................... 268 435 455 Sectors (131 072 Mb)
Capacity available in LBA 48 Mode................. 312 500 000 Sectors (152 587.9 Mb)
Available DMA Mode
Multiword DMA Mode 0
Multiword DMA Mode 1
Multiword DMA Mode 2
Active DMA Mode
Active UDMA/33 modes
Ultra DMA/33 Mode 0
Ultra DMA/33 Mode 1
Ultra DMA/33 Mode 2
Ultra DMA/33 Mode 3
Ultra DMA/33 Mode 4
Ultra DMA/33 Mode 5
Ultra DMA/33 Mode 6
Current UDMA/33 mode........................................ Ultra DMA/33 Mode 4
Current PIO mode
Supported Enhanced PIO Modes
PIO MODE 3
PIO MODE 4
Minimal multiword DMA cycle time............................ 120 ns
Recommended multiword DMA cycle time........................ 120 ns
Minimal multiword PIO cycle time w/o stream control......... 120 ns
Minimal multiword PIO cycle time with IORDY................. 120 ns
Supported standards
ATA - 3
ATA - 4
ATA - 5
ATA - 6
Supported Command Sets
S.M.A.R.T functions
Security control
Security system............................................. Supported
condition flags :
password set...................................... NO
HDD Locked........................................ NO
HDD Frozen........................................ NO
wrong password count exceeded..................... NO
security erase support............................ NO
security level.................................... HIGH
Master code................................................. 0000
Zero Alpha: zeroalpha.com.au
 Post subject: Re: Hawk WD1600JS No access to data
PostPosted: January 21st, 2010, 8:26
Wow its amazing what a strong cup of coffee and a second look at the details can do for you. Smart modules are obviously corrupt. Guess what you get after rebuilding them...
Special shout out to Igor, Thanks mate!
Users browsing this forum: No registered users and 14 guests
