| Hawk WD1600JS No access to data http://forum.hddguru.com/viewtopic.php?f=11&t=14589 |
Page 1 of 1 |
| Author: | Zero Alpha [ January 20th, 2010, 20:01 ] |
| Post subject: | Hawk WD1600JS No access to data |
Heads test pass ok. If I try and access data it produces ABR on every LBA. Translator regeneration fails. Techno mode key Techno mode key......................... : Ok RAM: Zone allocation table................... : Ok Cyl Count............................... : 83935 SA SPT.................................. : 720 Head number reading..................... : Ok Heads number............................ : 4 ROM: ROM reading............................. : Ok ROM Data size........................... : 128 Kb ROM version............................. : 10.8WE ROM generation.......................... : 10.8WE Link table version...................... : 02.8A. Heads configuration..................... : by map Heads number............................ : 4 Heads number in use..................... : 4 Switched off heads...................... : No Head map................................ : 0,1,4,5 Firmware version........................ : 108W? Service area: SA dir reading.......................... : Ok (Copy 0) Configuration reading................... : Ok Master Password......................... : has not been set User Password........................... : has not been set SA structure test Module 01 Copy 0........................ : Ok Module 01 Copy 1........................ : Ok Module 38 Copy 0........................ : Ok Module reading error: Physical read error C/H/S: -1/1/174 - Device Error Detected: "DISK ECU UNSAFE ERROR" Module 38 Copy 1........................ : Error Module 17 Copy 0........................ : Ok Module 17 Copy 1........................ : Ok Module 15 Copy 0........................ : Ok Module reading error: Physical read error C/H/S: -1/1/312 - Device Error Detected: "DISK ECU UNSAFE ERROR" Module 15 Copy 1........................ : Error Module 39 Copy 0........................ : Ok Module reading error: Physical read error C/H/S: -1/1/344 - Device Error Detected: "DISK ECU UNSAFE ERROR" Module 39 Copy 1........................ : Error Module 2F Copy 0........................ : Ok Module 2F Copy 1........................ : Ok Module 50 Copy 0........................ : Ok Module 50 Copy 1........................ : Ok Module 62 Copy 0........................ : Ok Module 62 Copy 1........................ : Ok Module 35 Copy 0........................ : Ok Module 35 Copy 1........................ : Ok Module 02 Copy 0........................ : Ok Module 02 Copy 1........................ : Ok Module 33 Copy 0........................ : Ok Module reading error: Physical read error C/H/S: -2/1/174 - Device Error Detected: "DISK ECU UNSAFE ERROR" Module 33 Copy 1........................ : Error Module 26 Copy 0........................ : Ok Module reading error: Physical read error C/H/S: -2/1/527 - Device Error Detected: "DISK DAM ERROR" Module 26 Copy 1........................ : Error Module 28 Copy 0........................ : Ok Module 28 Copy 1........................ : Ok Module 2D Copy 0........................ : Ok Module 2D Copy 1........................ : Ok Module 1B Copy 0........................ : Ok Module reading error: Physical read error C/H/S: -3/1/312 - Device Error Detected: "DISK DAM ERROR" Module 1B Copy 1........................ : Error Module 1C Copy 0........................ : Ok Module 1C Copy 1........................ : Ok Module 40 Copy 0........................ : Ok Module 40 Copy 1........................ : Ok Module 34 Copy 0........................ : Ok Module reading error: Physical read error C/H/S: -3/1/464 - Device Error Detected: "DISK ECU UNSAFE ERROR" Module 34 Copy 1........................ : Error Module 29 Copy 0........................ : Ok Module 29 Copy 1........................ : Ok Module 51 Copy 0........................ : Ok Module 51 Copy 1........................ : Ok Module 2E Copy 0........................ : Ok Module reading error: Physical read error C/H/S: -8/1/175 - Device Error Detected: "DISK ECU UNSAFE ERROR" Module 2E Copy 1........................ : Error Module reading error: Physical read error C/H/S: -8/0/294 - Device Error Detected: "DISK ECU UNSAFE ERROR" Module 21 Copy 0........................ : Error Module reading error: Physical read error C/H/S: -8/1/294 - Device Error Detected: "DISK ECU UNSAFE ERROR" Module 21 Copy 1........................ : Error Module 19 Copy 0........................ : Ok Module 19 Copy 1........................ : Ok Module 43 Copy 0........................ : Ok Module 43 Copy 1........................ : Ok Module 04 Copy 0........................ : Ok Module 04 Copy 1........................ : Ok Module 2A Copy 0........................ : Ok Module 2A Copy 1........................ : Ok Module 52 Copy 0........................ : Ok Module 52 Copy 1........................ : Ok Module 11 Copy 0........................ : Ok Module reading error: Physical read error C/H/S: -9/1/175 - Device Error Detected: "DISK ECU UNSAFE ERROR" Module 11 Copy 1........................ : Error Module 24 Copy 0........................ : Ok Module reading error: Physical read error C/H/S: -9/1/310 - Device Error Detected: "DISK ECU UNSAFE ERROR" Module 24 Copy 1........................ : Error Module 1E Copy 0........................ : Ok Module 1E Copy 1........................ : Ok Module 42 Copy 0........................ : Ok Module 42 Copy 1........................ : Ok Module 05 Copy 0........................ : Ok Module 05 Copy 1........................ : Ok Module 0C Copy 0........................ : Ok Module 0C Copy 1........................ : Ok Module 53 Copy 0........................ : Ok Module 53 Copy 1........................ : Ok Module 31 Copy 0........................ : Ok Module 31 Copy 1........................ : Ok Module 23 Copy 0........................ : Ok Module reading error: Physical read error C/H/S: -10/1/310 - Device Error Detected: "DISK ECU UNSAFE ERROR" Module 23 Copy 1........................ : Error Module 61 Copy 0........................ : Ok Module reading error: Physical read error C/H/S: -10/1/342 - Device Error Detected: "DISK ECU UNSAFE ERROR" Module 61 Copy 1........................ : Error Module 4C Copy 0........................ : Ok Module 4C Copy 1........................ : Ok Module 07 Copy 0........................ : Ok Module 07 Copy 1........................ : Ok Module 4A Copy 0........................ : Ok Module 4A Copy 1........................ : Ok Module 36 Copy 0........................ : Ok Module 36 Copy 1........................ : Ok Module 25 Copy 0........................ : Ok Module reading error: Physical read error C/H/S: -11/1/175 - Device Error Detected: "DISK ECU UNSAFE ERROR" Module 25 Copy 1........................ : Error Module reading error: Physical read error C/H/S: -11/0/262 - Device Error Detected: "DISK ECU UNSAFE ERROR" Module 22 Copy 0........................ : Error Module reading error: Physical read error C/H/S: -11/1/262 - Device Error Detected: "DISK ECU UNSAFE ERROR" Module 22 Copy 1........................ : Error Module 32 Copy 0........................ : Ok Module 32 Copy 1........................ : Ok Module 41 Copy 0........................ : Ok Module 41 Copy 1........................ : Ok Module 06 Copy 0........................ : Ok Module 06 Copy 1........................ : Ok Module 49 Copy 0........................ : Ok Module 49 Copy 1........................ : Ok Module 37 Copy 0........................ : Ok Module 37 Copy 1........................ : Ok Module C4 Copy 0........................ : Ok Module reading error: Physical read error C/H/S: -3/1/521 - Device Error Detected: "DISK ECU UNSAFE ERROR" Module C4 Copy 1........................ : Error Module C5 Copy 0........................ : Ok Module C5 Copy 1........................ : Ok Module CC Copy 0........................ : Ok Module CC Copy 1........................ : Ok Module CA Copy 0........................ : Ok Module reading error: Physical read error C/H/S: -3/1/601 - Device Error Detected: "DISK ECU UNSAFE ERROR" Module CA Copy 1........................ : Error Module CB Copy 0........................ : Ok Module CB Copy 1........................ : Ok Module CD Copy 0........................ : Ok Module CD Copy 1........................ : Ok Module CF Copy 0........................ : Ok Module CF Copy 1........................ : Ok Module CE Copy 0........................ : Ok Module CE Copy 1........................ : Ok Module 91 Copy 0........................ : Ok Module 91 Copy 1........................ : Ok Module 92 Copy 0........................ : Ok Module 92 Copy 1........................ : Ok Module 93 Copy 0........................ : Ok Module 93 Copy 1........................ : Ok Module C1 Copy 0........................ : Ok Module C1 Copy 1........................ : Ok Module C2 Copy 0........................ : Ok Module C2 Copy 1........................ : Ok Module C7 Copy 0........................ : Ok Module C7 Copy 1........................ : Ok Module 9E Copy 0........................ : Ok Module 9E Copy 1........................ : Ok Module B1 Copy 0........................ : Ok Module B1 Copy 1........................ : Ok Module E0 Copy 0........................ : Ok Module reading error: Physical read error C/H/S: -6/1/179 - Device Error Detected: "DISK ECU UNSAFE ERROR" Module E0 Copy 1........................ : Error Module E8 Copy 0........................ : Ok Module reading error: Physical read error C/H/S: -7/1/175 - Device Error Detected: "DISK ECU UNSAFE ERROR" Module E8 Copy 1........................ : Error Module FE Copy 0........................ : Ok Module reading error: Physical read error C/H/S: -10/1/465 - Device Error Detected: "DISK ECU UNSAFE ERROR" Module FE Copy 1........................ : Error Module B6 Copy 0........................ : Ok Module reading error: Physical read error C/H/S: -7/1/522 - Device Error Detected: "DISK ECU UNSAFE ERROR" Module B6 Copy 1........................ : Error Module B7 Copy 0........................ : Ok Module B7 Copy 1........................ : Ok Module D5 Copy 0........................ : Ok Module reading error: Physical read error C/H/S: -9/1/465 - Device Error Detected: "DISK ECU UNSAFE ERROR" Module D5 Copy 1........................ : Error Module DA Copy 0........................ : Ok Module reading error: Physical read error C/H/S: -8/1/465 - Device Error Detected: "DISK ECU UNSAFE ERROR" Module DA Copy 1........................ : Error Module DB Copy 0........................ : Ok Module reading error: Physical read error C/H/S: -11/1/465 - Device Error Detected: "DISK ECU UNSAFE ERROR" Module DB Copy 1........................ : Error Module DF Copy 0........................ : Ok Module DF Copy 1........................ : Ok Module DD Copy 0........................ : Ok Module reading error: Physical read error C/H/S: -12/1/175 - Device Error Detected: "DISK ECU UNSAFE ERROR" Module DD Copy 1........................ : Error Module D6 Copy 0........................ : Ok Module reading error: Physical read error C/H/S: -12/1/204 - Device Error Detected: "DISK ECU UNSAFE ERROR" Module D6 Copy 1........................ : Error Module D7 Copy 0........................ : Ok Module reading error: Physical read error C/H/S: -12/1/310 - Device Error Detected: "DISK ECU UNSAFE ERROR" Module D7 Copy 1........................ : Error Module D2 Copy 0........................ : Ok Module D2 Copy 1........................ : Ok Module BB Copy 0........................ : Ok Module reading error: Physical read error C/H/S: -12/1/465 - Device Error Detected: "DISK ECU UNSAFE ERROR" Module BB Copy 1........................ : Error Module D9 Copy 0........................ : Ok Module D9 Copy 1........................ : Ok Module D4 Copy 0........................ : Ok Module D4 Copy 1........................ : Ok Module DC Copy 0........................ : Ok Module reading error: Physical read error C/H/S: -13/1/176 - Device Error Detected: "DISK DAM ERROR" Module DC Copy 1........................ : Error Module D0 Copy 0........................ : Ok Module D0 Copy 1........................ : Ok Module D3 Copy 0........................ : Ok Module reading error: Physical read error C/H/S: -13/1/310 - Device Error Detected: "DISK ECU UNSAFE ERROR" Module D3 Copy 1........................ : Error Module BA Copy 0........................ : Ok Module BA Copy 1........................ : Ok Module B9 Copy 0........................ : Ok Module reading error: Physical read error C/H/S: -13/1/466 - Device Error Detected: "DISK DAM ERROR" Module B9 Copy 1........................ : Error Module BC Copy 0........................ : Ok Module BC Copy 1........................ : Ok Module D8 Copy 0........................ : Ok Module D8 Copy 1........................ : Ok Module FD Copy 0........................ : Ok Module reading error: Physical read error C/H/S: -11/1/522 - Device Error Detected: "DISK ECU UNSAFE ERROR" Module FD Copy 1........................ : Error Module FB Copy 0........................ : Ok Module reading error: Physical read error C/H/S: -6/1/522 - Device Error Detected: "DISK DAM ERROR" Module FB Copy 1........................ : Error Module E6 Copy 0........................ : Ok Module reading error: Physical read error C/H/S: -13/1/523 - Device Error Detected: "DISK ECU UNSAFE ERROR" Module E6 Copy 1........................ : Error Module E7 Copy 0........................ : Ok Module E7 Copy 1........................ : Ok Module BE Copy 0........................ : Ok Module BE Copy 1........................ : Ok Module B8 Copy 0........................ : Ok Module B8 Copy 1........................ : Ok Module BF Copy 0........................ : Ok Module BF Copy 1........................ : Ok Module FC Copy 0........................ : Ok Module FC Copy 1........................ : Ok Module EE Copy 0........................ : Ok Module EE Copy 1........................ : Ok Module E1 Copy 0........................ : Ok Module reading error: Physical read error C/H/S: -33/1/183 - Device Error Detected: "DISK ECU UNSAFE ERROR" Module E1 Copy 1........................ : Error Module E2 Copy 0........................ : Ok Module reading error: Physical read error C/H/S: -34/1/179 - Device Error Detected: "DISK ECU UNSAFE ERROR" Module E2 Copy 1........................ : Error Module E3 Copy 0........................ : Ok Module reading error: Physical read error C/H/S: -35/1/179 - Device Error Detected: "DISK ECU UNSAFE ERROR" Module E3 Copy 1........................ : Error Module E4 Copy 0........................ : Ok Module reading error: Physical read error C/H/S: -36/1/179 - Device Error Detected: "DISK ECU UNSAFE ERROR" Module E4 Copy 1........................ : Error Module E5 Copy 0........................ : Ok Module reading error: Physical read error C/H/S: -37/1/179 - Device Error Detected: "DISK ECU UNSAFE ERROR" Module E5 Copy 1........................ : Error Module E9 Copy 0........................ : Ok Module reading error: Physical read error C/H/S: -38/1/179 - Device Error Detected: "DISK ECU UNSAFE ERROR" Module E9 Copy 1........................ : Error Module EA Copy 0........................ : Ok Module reading error: Physical read error C/H/S: -39/1/184 - Device Error Detected: "DISK ECU UNSAFE ERROR" Module EA Copy 1........................ : Error Module EB Copy 0........................ : Ok Module reading error: Physical read error C/H/S: -40/1/180 - Device Error Detected: "DISK ECU UNSAFE ERROR" Module EB Copy 1........................ : Error Module EC Copy 0........................ : Ok Module reading error: Physical read error C/H/S: -41/1/180 - Device Error Detected: "DISK ECU UNSAFE ERROR" Module EC Copy 1........................ : Error Module ED Copy 0........................ : Ok Module reading error: Physical read error C/H/S: -42/1/180 - Device Error Detected: "DISK ECU UNSAFE ERROR" Module ED Copy 1........................ : Error Module DE Copy 0........................ : Ok Module reading error: Physical read error C/H/S: -14/1/176 - Device Error Detected: "DISK ECU UNSAFE ERROR" Module DE Copy 1........................ : Error Module FA Copy 0........................ : Ok Module reading error: Physical read error C/H/S: -14/1/315 - Device Error Detected: "DISK ECU UNSAFE ERROR" Module FA Copy 1........................ : Error Defect list header has not been read P-List reading.......................... : Ok G-List reading.......................... : Ok HDD parameters CONFIGURATION GENERAL INFORMATION: ATA device Fixed device and/or controller Logical cylinders count..................................... 16383 Logical sectors per track................................... 63 Logical heads count......................................... 16 Model....................................................... WDC WD1600JS-75NCB1 Serial number............................................... WD-WMANM1689775 Firmware.................................................... 10.02E01 Maximal block size for READ/WRITE MULTIPLE commands......... 16 Features Stop Timer Value IORDY............................................. Supported LBA Mode.......................................... Supported DMA Mode.......................................... Supported Current Logical Parameters Cylinders......................................... 16 383 Heads............................................. 16 Sectors........................................... 63 Capacity.......................................... 16 514 064 Sectors (8 063.5 Mb) Capacity available in LBA Mode.................... 268 435 455 Sectors (131 072 Mb) Capacity available in LBA 48 Mode................. 312 500 000 Sectors (152 587.9 Mb) Available DMA Mode Multiword DMA Mode 0 Multiword DMA Mode 1 Multiword DMA Mode 2 Active DMA Mode Active UDMA/33 modes Ultra DMA/33 Mode 0 Ultra DMA/33 Mode 1 Ultra DMA/33 Mode 2 Ultra DMA/33 Mode 3 Ultra DMA/33 Mode 4 Ultra DMA/33 Mode 5 Ultra DMA/33 Mode 6 Current UDMA/33 mode........................................ Ultra DMA/33 Mode 4 Current PIO mode Supported Enhanced PIO Modes PIO MODE 3 PIO MODE 4 Minimal multiword DMA cycle time............................ 120 ns Recommended multiword DMA cycle time........................ 120 ns Minimal multiword PIO cycle time w/o stream control......... 120 ns Minimal multiword PIO cycle time with IORDY................. 120 ns Supported standards ATA - 3 ATA - 4 ATA - 5 ATA - 6 Supported Command Sets S.M.A.R.T functions Security control Security system............................................. Supported condition flags : password set...................................... NO HDD Locked........................................ NO HDD Frozen........................................ NO wrong password count exceeded..................... NO security erase support............................ NO security level.................................... HIGH Master code................................................. 0000 |
| Author: | Zero Alpha [ January 21st, 2010, 8:26 ] |
| Post subject: | Re: Hawk WD1600JS No access to data |
Wow its amazing what a strong cup of coffee and a second look at the details can do for you. Smart modules are obviously corrupt. Guess what you get after rebuilding them... Special shout out to Igor, Thanks mate! |
