 Post subject: WD2000BB-00GUC0 modules needed please
PostPosted: January 22nd, 2010, 16:16
Hi folks, anyon has modules for WD2000BB-00GUC0. I am trying to fix MD02000-BABW, DID BB00GUC02000. Thanks a lot.
 Post subject: Re: WD2000BB-00GUC0 modules needed please
PostPosted: January 27th, 2010, 16:00
Hi to all,
So far, I had the SA structure test on this drive with some errors. I am wondering I can fix it or not if I get the modules from other drives. Any ideas will be appreciated.
SA MODULES LIST
Id:Copy: Importance:Cyl :Head:Sector:Size:Read : Hdr : CS : CS Value: Date : Vers.: Desription
------------------------------------------------------------------------------------------19: 0 : B : -1: 0: 2: 21:Yes : Ok : Ok : 7A :20-08-05:0100J :Loaded part of microprogram code
19: 1 : B : -1: 1: 2: 21:Yes : Ok : Ok : 7A :20-08-05:0100J :Loaded part of microprogram code
1B: 0 : B : -1: 0: 24: 6:Yes : Ok : Ok : B3 :20-08-05:0100J :Loaded part of microprogram code
1B: 1 : B : -1: 1: 24: 6:Yes : Ok : Ok : B3 :20-08-05:0100J :Loaded part of microprogram code
1A: 0 : : -1: 0: 31: 4:Yes : Ok : Ok : CB :20-08-05:0200? :
1A: 1 : : -1: 1: 31: 4:Yes : Ok : Ok : CB :20-08-05:0200? :
1F: 0 : : -1: 0: 36: 1:Yes : Ok : Ok : CA :20-08-05:0100J :
1F: 1 : : -1: 1: 36: 1:Yes : Ok : Ok : CA :20-08-05:0100J :
AF: 0 : : -1: 0: 38: 5:Yes : Ok : Ok : E1 :20-08-05:0100J :
AF: 1 : : -1: 1: 38: 5:Yes : Ok : Ok : E1 :20-08-05:0100J :
AE: 0 : : -1: 0: 44: 30:Yes : Ok : Ok : C1 :20-08-05:0100J :
AE: 1 : : -1: 1: 44: 30:Yes : Ok : Ok : C1 :20-08-05:0100J :
AD: 0 : : -1: 0: 75: 2:Yes : Ok : Ok : F0 :20-08-05:0100? :
AD: 1 : : -1: 1: 75: 2:Yes : Ok : Ok : F0 :20-08-05:0100? :
AC: 0 : : -1: 0: 78: 7:Yes : Ok : Ok : D4 :20-08-05:0100? :
AC: 1 : : -1: 1: 78: 7:Yes : Ok : Ok : D4 :20-08-05:0100? :
A0: 0 : : -1: 0: 86: 17:Yes : Ok : Ok : 2E :20-08-05:0100? :
A0: 1 : : -1: 1: 86: 17:Yes : Ok : Ok : 2E :20-08-05:0100? :
A1: 0 : : -1: 0: 104: 29:Yes : Ok : Ok : 21 :20-08-05:0100? :
A1: 1 : : -1: 1: 104: 29:Yes : Ok : Ok : 21 :20-08-05:0100? :
A2: 0 : : -1: 0: 134: 9:Yes : Ok : Ok : 34 :20-08-05:0100? :
A2: 1 : : -1: 1: 134: 9:Yes : Ok : Ok : 34 :20-08-05:0100? :
A3: 0 : : -1: 0: 144: 13:Yes : Ok : Ok : 2F :20-08-05:0100? :
A3: 1 : : -1: 1: 144: 13:Yes : Ok : Ok : 2F :20-08-05:0100? :
42: 0 : B : -2: 0: 0: 2:Yes : Ok : Ok : 0A :29-03-06:0202? :Configuration (HDD ID)
42: 1 : B : -2: 1: 0: 2:Yes : Ok : Ok : 0A :29-03-06:0202? :Configuration (HDD ID)
43: 0 : Dd : -2: 0: 3: 360:Yes : Ok : Ok : 45 :20-08-05:0200? :P-List (Primary defect list)
43: 1 : Dd : -2: 1: 3: 360:Yes : Ok : Ok : 45 :20-08-05:0200? :P-List (Primary defect list)
44: 0 : C : -2: 0: 364: 8:Yes : Ok : Ok : BE :29-03-06:0200? :G-List (Grown defect list)
44: 1 : C : -2: 1: 364: 8:Yes : Ok : Ok : BE :29-03-06:0200? :G-List (Grown defect list)
59: 0 : Dr : -2: 0: 373: 4:Yes : Ok : Ok : 4C :20-08-05:0100? :T-List (Track defect list)
59: 1 : Dr : -2: 1: 373: 4:Yes : Ok : Ok : 4C :20-08-05:0100? :T-List (Track defect list)
5A: 0 : : -2: 0: 378: 1:Yes : Ok : Ok : 46 :20-08-05:0100? :
5A: 1 : : -2: 1: 378: 1:Yes : Ok : Ok : 46 :20-08-05:0100? :
20: 0 : Ad : -2: 0: 380: 144:Yes : Ok : Ok : BD :01-01-98:0701? :Translator
20: 1 : Ad : -2: 1: 380: 144:Yes : Ok : Ok : BD :01-01-98:0701? :Translator
25: 0 : Ad : -2: 0: 525: 15:Yes : Ok : Ok : 33 :01-01-98:0600? :Translator
25: 1 : Ad : -2: 1: 525: 15:Yes : Ok : Ok : 33 :01-01-98:0600? :Translator
3C: 0 : : -2: 0: 541: 6:Yes :Error: Ok : EB : : :
3C: 1 : : -2: 1: 541: 6:Yes :Error: Ok : EB : : :
4C: 0 : As : -2: 0: 548: 2:Yes : Ok : Ok : AC :20-08-05:0200? :Adaptive data
4C: 1 : As : -2: 1: 548: 2:Yes : Ok : Ok : AC :20-08-05:0200? :Adaptive data
70: 0 : : -2: 0: 551: 2:Yes : Ok : Ok : C7 :20-08-05:0200? :
70: 1 : : -2: 1: 551: 2:Yes : Ok : Ok : C7 :20-08-05:0200? :
72: 0 : : -2: 0: 554: 2:Yes : Ok : Ok : C5 :20-08-05:0200? :
72: 1 : : -2: 1: 554: 2:Yes : Ok : Ok : C5 :20-08-05:0200? :
74: 0 : : -2: 0: 557: 2:Yes : Ok : Ok : C3 :20-08-05:0200? :
74: 1 : : -2: 1: 557: 2:Yes : Ok : Ok : C3 :20-08-05:0200? :
4D: 0 : As : -2: 0: 560: 2:Yes : Ok : Ok : 0E :20-08-05:0200? :Adaptive data
4D: 1 : As : -2: 1: 560: 2:Yes : Ok : Ok : 0E :20-08-05:0200? :Adaptive data
71: 0 : : -2: 0: 563: 2:Yes : Ok : Ok : E5 :20-08-05:0200? :
71: 1 : : -2: 1: 563: 2:Yes : Ok : Ok : E5 :20-08-05:0200? :
73: 0 : : -2: 0: 566: 2:Yes : Ok : Ok : E3 :20-08-05:0200? :
73: 1 : : -2: 1: 566: 2:Yes : Ok : Ok : E3 :20-08-05:0200? :
75: 0 : : -2: 0: 569: 2:Yes : Ok : Ok : E1 :20-08-05:0200? :
75: 1 : : -2: 1: 569: 2:Yes : Ok : Ok : E1 :20-08-05:0200? :
18: 0 : : -2: 0: 572: 2:Yes : Ok : Ok : 26 :20-08-05:0100? :Table 2 sectors
18: 1 : : -2: 1: 572: 2:Yes : Ok : Ok : 26 :20-08-05:0100? :Table 2 sectors
2B: 0 : B : -2: 0: 575: 25:Yes : Ok : Ok : 4D :20-08-05:0100? :S.M.A.R.T. Log
2B: 1 : B : -2: 1: 575: 25:Yes : Ok : Ok : 4D :20-08-05:0100? :S.M.A.R.T. Log
4E: 0 : As : -2: 0: 603: 32:Yes : Ok : Ok : F3 :01-01-01:0107? :Ver. Info Log
4E: 1 : As : -2: 1: 603: 32:Yes : Ok : Ok : F3 :01-01-01:0107? :Ver. Info Log
2C: 0 : B : -3: 0: 0: 10:Yes : Ok : Ok : 2E :20-08-05:0104? :S.M.A.R.T. Log
2C: 1 : B : -3: 1: 0: 10:Yes : Ok : Ok : 2E :20-08-05:0104? :S.M.A.R.T. Log
2E: 0 : B : -3: 0: 13: 24:Yes : Ok : Ok : 76 :20-08-05:0712? :Original S.M.A.R.T. Parameters table
2E: 1 : B : -3: 1: 13: 24:Yes : Ok : Ok : 76 :20-08-05:0712? :Original S.M.A.R.T. Parameters table
5B: 0 : : -3: 0: 40: 1:Yes : Ok : Ok : 3D :20-08-05:0100? :
5B: 1 : : -3: 1: 40: 1:Yes : Ok : Ok : 3D :20-08-05:0100? :
26: 0 : B : -3: 0: 44: 24:Yes : Ok : Ok : 5C :20-08-05:0712? :S.M.A.R.T. Parameters
26: 1 : B : -3: 1: 44: 24:Yes : Ok : Ok : 5C :20-08-05:0712? :S.M.A.R.T. Parameters
38: 0 : : -3: 0: 71: 6:Yes :Error: Ok : A4 : : :
38: 1 : : -3: 1: 71: 6:Yes :Error: Ok : A4 : : :
48: 0 : As : -3: 0: 80: 3:Yes : Ok : Ok : 4E :20-08-05:0.00? :Adaptive data
48: 1 : As : -3: 1: 80: 3:Yes : Ok : Ok : 4E :20-08-05:0.00? :Adaptive data
49: 0 : As : -3: 0: 86: 2:Yes : Ok : Ok : 14 :01-01-98:0.11? :Adaptive data
49: 1 : As : -3: 1: 86: 2:Yes : Ok : Ok : 14 :01-01-98:0.11? :Adaptive data
4A: 0 : As : -3: 0: 91: 4:Yes : Ok : Ok : 09 :20-08-05:0100? :Adaptive data
4A: 1 : As : -3: 1: 91: 4:Yes : Ok : Ok : 09 :20-08-05:0100? :Adaptive data
30: 0 : : -3: 0: 98: 12:Yes :Error: Ok : 21 : : :
30: 1 : : -3: 1: 98: 12:Yes :Error: Ok : 21 : : :
1C: 0 : : -3: 0: 118: 57:Yes : Ok : Ok : 74 :20-08-05:0100J :
1C: 1 : : -3: 1: 118: 57:Yes : Ok : Ok : 74 :20-08-05:0100J :
34: 0 : : -3: 0: 183: 48:Yes :Error: Ok : 27 : : :
34: 1 : : -3: 1: 183: 48:Yes :Error: Ok : 27 : : :
12: 0 : B : -3: 0: 239: 24:Yes : Ok : Ok : 6F :20-08-05:0106J :Loaded part of microprogram code
12: 1 : B : -3: 1: 239: 24:Yes : Ok : Ok : 6F :20-08-05:0106J :Loaded part of microprogram code
11: 0 : B : -3: 0: 266: 76:Yes : Ok : Ok : 65 :20-08-05:0100J :Loaded part of microprogram code
11: 1 : B : -3: 1: 266: 76:Yes : Ok : Ok : 65 :20-08-05:0100J :Loaded part of microprogram code
14: 0 : B : -3: 0: 345: 65:Yes : Ok : Ok : D5 :20-08-05:0100J :Loaded part of microprogram code
14: 1 : B : -3: 1: 345: 65:Yes : Ok : Ok : D5 :20-08-05:0100J :Loaded part of microprogram code
61: 0 : B : -3: 0: 413: 24:Yes : Ok : Ok : 65 :20-08-05:0110J :Flash rewriting microprogram (LDuCODE)
61: 1 : B : -3: 1: 413: 24:Yes : Ok : Ok : 65 :20-08-05:0110J :Flash rewriting microprogram (LDuCODE)
02: 0 : B : -3: 0: 440: 118:No : : : : : :Loaded part of microprogram code
02: 1 : B : -3: 1: 440: 118:No : : : : : :Loaded part of microprogram code
BF: 0 : : -3: 0: 566: 2:Yes : Ok : Ok : 6A :20-08-05:0100? :
BF: 1 : : -3: 1: 566: 2:Yes : Ok : Ok : 6A :20-08-05:0100? :
45: 0 : : -3: 0: 571: 15:Yes :Error: Ok : 17 : : :
45: 1 : : -3: 1: 571: 15:Yes :Error: Ok : 17 : : :
4B: 0 : As : -3: 0: 587: 3:Yes : Ok : Ok : 01 :20-08-05:0100? :Adaptive data
4B: 1 : As : -3: 1: 587: 3:Yes : Ok : Ok : 01 :20-08-05:0100? :Adaptive data
21: 0 : B : -3: 0: 591: 10:Yes : Ok : Ok : D3 :20-08-05:0104? :Event log
21: 1 : B : -3: 1: 591: 10:Yes : Ok : Ok : D3 :20-08-05:0104? :Event log
17: 0 : : -3: 0: 604: 2:Yes : Ok : Ok : 76 :20-08-05:0100? :Table 2 sectors
17: 1 : : -3: 1: 604: 2:Yes : Ok : Ok : 76 :20-08-05:0100? :Table 2 sectors
2A: 0 : B : -3: 0: 607: 33:Yes : Ok : Ok : 46 :20-08-05:0100? :S.M.A.R.T. Log
2A: 1 : B : -3: 1: 607: 33:Yes : Ok : Ok : 46 :20-08-05:0100? :S.M.A.R.T. Log
2F: 0 : B : -3: 0: 643: 8:Yes :Error: Ok : AA : : :S.M.A.R.T. Log (reserved)
2F: 1 : B : -3: 1: 643: 8:Yes :Error: Ok : AA : : :S.M.A.R.T. Log (reserved)
1E: 0 : : -3: 0: 652: 4:Yes : Ok : Ok : BD :20-08-05:0100? :
1E: 1 : : -3: 1: 652: 4:Yes : Ok : Ok : BD :20-08-05:0100? :
5C: 0 : : -3: 0: 657: 2:Yes : Ok : Ok : 1E :20-08-05:0100? :
5C: 1 : : -3: 1: 657: 2:Yes : Ok : Ok : 1E :20-08-05:0100? :
29: 0 : C : -8: 0: 280: 24:Yes : Ok : Ok : D7 :20-08-05:0712? :S.M.A.R.T. Parameters
29: 1 : C : -8: 1: 280: 24:Yes : Ok : Ok : D7 :20-08-05:0712? :S.M.A.R.T. Parameters
2D: 0 : C : -8: 0: 306: 24:Yes : Ok : Ok : D3 :20-08-05:0712? :S.M.A.R.T. Parameters
2D: 1 : C : -8: 1: 306: 24:Yes : Ok : Ok : D3 :20-08-05:0712? :S.M.A.R.T. Parameters
01: 0 : B : -2: 0: 638: 12:Yes :Error: Ok : 0C : : :Loaded part of microprogram code
01: 1 : B : -2: 1: 638: 12:Yes :Error: Ok : 0C : : :Loaded part of microprogram code
10: 0 : B : -2: 0: 658: 48:Yes :Error: Ok : 47 : : :Loaded part of microprogram code
10: 1 : B : -2: 1: 658: 48:Yes :Error: Ok : 47 : : :Loaded part of microprogram code
22: 0 : B : -2: 0: 714: 6:Yes :Error: Ok : 1E : : :Translator
22: 1 : B : -2: 1: 714: 6:Yes :Error: Ok : 1E : : :Translator
23: 0 : B : -2: 0: 723: 6:Yes :Error: Ok : E2 : : :Translator
23: 1 : B : -2: 1: 723: 6:Yes :Error: Ok : E2 : : :Translator
46: 0 : As : -2: 0: 730: 15:Yes :Error: Ok : BD : : :Adaptive data
46: 1 : As : -2: 1: 730: 15:Yes :Error: Ok : BD : : :Adaptive data
31: 0 : : -2: 0: 746: 12:Yes : Ok : Ok : DE :20-08-05:0100J :
31: 1 : : -2: 1: 746: 12:Yes : Ok : Ok : DE :20-08-05:0100J :
35: 0 : : -2: 0: 766: 48:Yes : Ok : Ok : 90 :20-08-05:0100J :
35: 1 : : -2: 1: 766: 48:Yes : Ok : Ok : 90 :20-08-05:0100J :
39: 0 : : -2: 0: 822: 5:Yes : Ok : Ok : 93 :20-08-05:R100? :
39: 1 : : -2: 1: 822: 5:Yes : Ok : Ok : 93 :20-08-05:R100? :
3D: 0 : : -2: 0: 830: 5:Yes : Ok : Ok : AF :20-08-05:R100? :
3D: 1 : : -2: 1: 830: 5:Yes : Ok : Ok : AF :20-08-05:R100? :
4F: 0 : : -2: 0: 836: 15:Yes : Ok : Ok : 08 :20-08-05:0300? :
4F: 1 : : -2: 1: 836: 15:Yes : Ok : Ok : 08 :20-08-05:0300? :
C3: 0 : : -1: 0: 158: 96:Yes : Ok : Ok : 9D :23-08-05:Fh0CJ :
C3: 1 : : -1: 1: 158: 96:Yes : Ok : Ok : 9D :23-08-05:Fh0CJ :
FA: 0 : Dr : -1: 0: 254: 74:Yes : Ok : Ok : C6 :23-08-05:58XXJ :Selfscan test microprogram
FA: 1 : Dr : -1: 1: 254: 74:Yes : Ok : Ok : C6 :23-08-05:58XXJ :Selfscan test microprogram
FF: 0 : Dr : -6: 0: 0: 705:Yes : Ok : Ok : 9C :23-08-05:590G? :Selfscan module
FF: 1 : Dr : -6: 1: 0: 705:Yes : Ok : Ok : 9C :23-08-05:590G? :Selfscan module
D4: 0 : Dr : -1: 0: 328: 464:No : : : : : :Selfscan test microprogram
D4: 1 : Dr : -1: 1: 328: 464:No : : : : : :Selfscan test microprogram
D5: 0 : Dr : -7: 0: 0: 464:Yes : Ok : Ok : 12 :23-08-05:590G? :Selfscan test microprogram
D5: 1 : Dr : -7: 1: 0: 464:Yes : Ok : Ok : 12 :23-08-05:590G? :Selfscan test microprogram
D6: 0 : Dr : -8: 0: 332: 464:Yes : Ok : Ok : 11 :23-08-05:590G? :Selfscan test microprogram
D6: 1 : Dr : -8: 1: 332: 464:Yes : Ok : Ok : 11 :23-08-05:590G? :Selfscan test microprogram
E9: 0 : Dr : -3: 0: 660: 94:Yes : Ok : Ok : F3 :23-08-05:58XXJ :Selfscan test microprogram
E9: 1 : Dr : -3: 1: 660: 94:Yes : Ok : Ok : F3 :23-08-05:58XXJ :Selfscan test microprogram
C4: 0 : Dr : -3: 0: 754: 90:Yes : Ok : Ok : 5E :23-08-05:P.0JJ :Calibrations module
C4: 1 : Dr : -3: 1: 754: 90:Yes : Ok : Ok : 5E :23-08-05:P.0JJ :Calibrations module
DA: 0 : Dr : -1: 0: 792: 81:Yes : Ok : Ok : 6E :23-08-05:58XXJ :Selfscan test microprogram
DA: 1 : Dr : -1: 1: 792: 81:Yes : Ok : Ok : 6E :23-08-05:58XXJ :Selfscan test microprogram
DB: 0 : Dr : -6: 0: 705: 81:Yes : Ok : Ok : 9B :23-08-05:58XXJ :Selfscan test microprogram
DB: 1 : Dr : -6: 1: 705: 81:Yes : Ok : Ok : 9B :23-08-05:58XXJ :Selfscan test microprogram
F4: 0 : Dr : -6: 0: 786: 81:Yes : Ok : Ok : 7F :23-08-05:58XXJ :Selfscan test microprogram
F4: 1 : Dr : -6: 1: 786: 81:Yes : Ok : Ok : 7F :23-08-05:58XXJ :Selfscan test microprogram
E5: 0 : Dr : -7: 0: 464: 81:Yes : Ok : Ok : 8C :23-08-05:58XXJ :Selfscan test microprogram
E5: 1 : Dr : -7: 1: 464: 81:Yes : Ok : Ok : 8C :23-08-05:58XXJ :Selfscan test microprogram
F5: 0 : Dr : -7: 0: 545: 77:Yes : Ok : Ok : 5F :23-08-05:58XXJ :Selfscan test microprogram
F5: 1 : Dr : -7: 1: 545: 77:Yes : Ok : Ok : 5F :23-08-05:58XXJ :Selfscan test microprogram
EF: 0 : Dr : -7: 0: 622: 74:Yes : Ok : Ok : 8B :23-08-05:58XXJ :Selfscan test microprogram
EF: 1 : Dr : -7: 1: 622: 74:Yes : Ok : Ok : 8B :23-08-05:58XXJ :Selfscan test microprogram
ED: 0 : Dr : -7: 0: 696: 63:Yes : Ok : Ok : A8 :23-08-05:58XXJ :Selfscan test microprogram
ED: 1 : Dr : -7: 1: 696: 63:Yes : Ok : Ok : A8 :23-08-05:58XXJ :Selfscan test microprogram
E4: 0 : Dr : -7: 0: 814: 51:Yes : Ok : Ok : B7 :23-08-05:58XXJ :Selfscan test microprogram
E4: 1 : Dr : -7: 1: 814: 51:Yes : Ok : Ok : B7 :23-08-05:58XXJ :Selfscan test microprogram
E3: 0 : Dr : -8: 0: 0: 57:Yes : Ok : Ok : 41 :23-08-05:58XXJ :Selfscan test microprogram
E3: 1 : Dr : -8: 1: 0: 57:Yes : Ok : Ok : 41 :23-08-05:58XXJ :Selfscan test microprogram
F3: 0 : Dr : -8: 0: 57: 54:Yes : Ok : Ok : B7 :23-08-05:58XXJ :Selfscan test microprogram
F3: 1 : Dr : -8: 1: 57: 54:Yes : Ok : Ok : B7 :23-08-05:58XXJ :Selfscan test microprogram
E7: 0 : Dr : -8: 0: 111: 54:Yes : Ok : Ok : 1A :23-08-05:58XXJ :Selfscan test microprogram
E7: 1 : Dr : -8: 1: 111: 54:Yes : Ok : Ok : 1A :23-08-05:58XXJ :Selfscan test microprogram
D7: 0 : Dr : -8: 0: 165: 55:Yes : Ok : Ok : 33 :23-08-05:58XXJ :Selfscan test microprogram
D7: 1 : Dr : -8: 1: 165: 55:Yes : Ok : Ok : 33 :23-08-05:58XXJ :Selfscan test microprogram
D8: 0 : Dr : -8: 0: 220: 50:Yes : Ok : Ok : 84 :23-08-05:58XXJ :Selfscan test microprogram
D8: 1 : Dr : -8: 1: 220: 50:Yes : Ok : Ok : 84 :23-08-05:58XXJ :Selfscan test microprogram
D2: 0 : Dr : -8: 0: 796: 50:Yes : Ok : Ok : E1 :23-08-05:58XXJ :Selfscan test microprogram
D2: 1 : Dr : -8: 1: 796: 50:Yes : Ok : Ok : E1 :23-08-05:58XXJ :Selfscan test microprogram
FD: 0 : Dr : -2: 0: 852: 5:Yes : Ok : Ok : 8F :23-08-05:`T0U? :Selfscan log
FD: 1 : Dr : -2: 1: 852: 5:Yes : Ok : Ok : 8F :23-08-05:`T0U? :Selfscan log
C5: 0 : Dr : -2: 0: 857: 3:Yes : Ok : Ok : 16 :25-02-05:P.0B? :Calibrations log (DCM)
C5: 1 : Dr : -2: 1: 857: 3:Yes : Ok : Ok : 16 :25-02-05:P.0B? :Calibrations log (DCM)
DC: 0 : Dr : -1: 0: 873: 1:Yes : Ok : Ok : FA :23-01-04:590G? :Selfscan test microprogram
DC: 1 : Dr : -1: 1: 873: 1:Yes : Ok : Ok : FA :23-01-04:590G? :Selfscan test microprogram
C6: 0 : : -1: 0: 874: 1:Yes : Ok : Ok : 92 :04-02-03:1.00? :
C6: 1 : : -1: 1: 874: 1:Yes : Ok : Ok : 92 :04-02-03:1.00? :
C9: 0 : : -2: 0: 860: 1:Yes : Ok : Ok : B9 :04-02-03:1.00? :
C9: 1 : : -2: 1: 860: 1:Yes : Ok : Ok : B9 :04-02-03:1.00? :
CD: 0 : : -2: 0: 861: 6:Yes : Ok : Ok : 1A :09-07-03:0100? :
CD: 1 : : -2: 1: 861: 6:Yes : Ok : Ok : 1A :09-07-03:0100? :
CF: 0 : : -2: 0: 867: 6:Yes : Ok : Ok : 0A :23-07-03:0100? :
CF: 1 : : -2: 1: 867: 6:Yes : Ok : Ok : 0A :23-07-03:0100? :
CB: 0 : : -3: 0: 844: 6:Yes : Ok : Ok : 0D :24-07-03:0100? :
CB: 1 : : -3: 1: 844: 6:Yes : Ok : Ok : 0D :24-07-03:0100? :
CC: 0 : : -3: 0: 850: 6:Yes : Ok : Ok : 19 :08-10-03:0100? :
CC: 1 : : -3: 1: 850: 6:Yes : Ok : Ok : 19 :08-10-03:0100? :
CA: 0 : : -3: 0: 856: 6:Yes : Ok : Ok : 1B :08-10-03:0100? :
CA: 1 : : -3: 1: 856: 6:Yes : Ok : Ok : 1B :08-10-03:0100? :
CE: 0 : : -3: 0: 862: 6:Yes : Ok : Ok : 11 :13-11-03:0100? :
CE: 1 : : -3: 1: 862: 6:Yes : Ok : Ok : 11 :13-11-03:0100? :
41: 0 : : -1: 0: 0: 2:Yes : Ok : Ok : 4D :29-03-06:21DEJ :Modules directory
41: 1 : : -1: 1: 0: 2:Yes : Ok : Ok : 4D :29-03-06:21DEJ :Modules directory
Users browsing this forum: No registered users and 30 guests
