Hi to all,
Have this in DE , when try to see the folders.
Ver: 10-09-2009 * 30-12-1899
...InitData
Could not find valid SuperBlock (or Copy)
1k block size
...End InitData
Error read root INode!
Scanning - broken
Analizing range 0 ...488397167
Analizing MBR
- slot 1
- slot 2
NTFS partition at LBA= 16128 is append!
NTFS Boot at LBA=488392064 is OK!
Analizing range 16128 ...488392063
Ver: 10-09-2009 * 10-09-2009
Check boot <Base > ... OK
Initializing NTFS variables
MftRecordSize = 1024
ClusterSize = 4096
IndexRecordSize = 4096
DataStart = 16128
TotalSectors = 488375936
MaxSector = 488392064
Load MFT map - Map filled
Load MFT map - Map empty
Attribute A0 is damaged6307594Root INDX is empty
The SA report:
SA structure.zip [13.27 KiB]
Downloaded 527 times
Any info will be great
Regards.
