 Post subject: MHZ2250BH Kernel mode?
PostPosted: February 7th, 2010, 17:32
Hi Folks
Is there any support for the MHZ2250BH or any way to force the PCB into Kernel mode for ROM reading?
No external ROM on these boards :(
*Sorry I did post on the Ace forums but this board has a lot more traffic*
Leigh
DataWreck Data Recovery Services
www.DataWreck.co.uk
 Post subject: Re: MHZ2250BH Kernel mode?
PostPosted: February 9th, 2010, 15:25
I presume you have a duff PCB?
I have had a few like this and had to search high & low for a compatible PCB and in most cases found one.
Post the pic of the drive label and I'll see if I have one. :-)
PostPosted: February 10th, 2010, 7:56
Yep your correct the PCB is not playing ball.
Label below
Cheers mate
Leigh
www.DataWreck.co.uk
PostPosted: February 11th, 2010, 21:09
Hint: Short circut and you will get kernel
PostPosted: February 21st, 2010, 12:33
have you replaced the fuse? to test the item with the symbol "N" :lol:
PostPosted: January 28th, 2011, 15:45
Any success? Have an identical disc, same rev.nr. It spins and i can hear the head moving. Need another pcb or any other ideas?
PostPosted: January 31st, 2011, 17:20
While I remember that job being sorted we'll have to dig through the case notes.
Will PM if found
www.DataWreck.co.uk
