MHZ2250BH Kernel mode?
http://forum.hddguru.com/viewtopic.php?f=11&t=14770
Author:  DataWreck [ February 7th, 2010, 17:32 ]
Post subject:  MHZ2250BH Kernel mode?
Hi Folks
Is there any support for the MHZ2250BH or any way to force the PCB into Kernel mode for ROM reading?
No external ROM on these boards :(
*Sorry I did post on the Ace forums but this board has a lot more traffic*
Leigh
Author:  pcimage [ February 9th, 2010, 15:25 ]
Post subject:  Re: MHZ2250BH Kernel mode?
I presume you have a duff PCB?
I have had a few like this and had to search high & low for a compatible PCB and in most cases found one.
Post the pic of the drive label and I'll see if I have one. :-)
Author:  DataWreck [ February 10th, 2010, 7:56 ]
Yep your correct the PCB is not playing ball.
Label below
Cheers mate
Leigh
Author:  TerraNova [ February 11th, 2010, 21:09 ]
Hint: Short circut and you will get kernel
Author:  book14 [ February 21st, 2010, 12:33 ]
have you replaced the fuse? to test the item with the symbol "N" :lol:
Author:  tecol [ January 28th, 2011, 15:45 ]
Any success? Have an identical disc, same rev.nr. It spins and i can hear the head moving. Need another pcb or any other ideas?
Author:  DataWreck [ January 31st, 2011, 17:20 ]
While I remember that job being sorted we'll have to dig through the case notes.
Will PM if found
