 Post subject: QT Plus AS ldr required
PostPosted: March 14th, 2010, 10:59
hi there,
I have a bad QT Plus AS 30g HD,
now I need the FW to repair it,
does somebody have ldr of this type of Plus AS,
and checksum for ldr 154x(x can be any letter) will be much better.
TKS in advance!!
 Post subject: Re: QT Plus AS ldr required
PostPosted: March 17th, 2010, 16:41
What are the symptoms?
BTW if u have a legitimate instance of PC3k U should have all these resources available from either the installation CD or your update box.
PostPosted: March 17th, 2010, 17:42
skyyy wrote:
hi there,
TKS in advance!!
Hi ,
I Have It ,PM Me
PostPosted: March 18th, 2010, 10:15
IF the problem is in some part of FW you can repair them, IF you want to refurbish them, it is much more complicated. Had to fight for 6 months before finding a working solution for AS / MX740.
Note : SS is mostly inoperative on 99,999% of these drives, if you play with it you'll end with totally screwed disk and it is very difficult to revive them. Same if you play with firmware and touch some critical parts.
Can't give more details, sorry.
PostPosted: March 18th, 2010, 11:10
Hi all,
The cp04 of FW shows AIY.254U, but the back body of HD shows AASY 1540, therefore, I think this harddrive was written the wrong FW before, and that is why I need the proper FW to get it back.
Any help/suggestion will be much appreciate, and any discussion will be more help as well, thanks guy who care my problem :D
PostPosted: March 18th, 2010, 15:07
It will be IMPOSSIBLE for you to write ANYTHING if the adaptives are overwritten (normal way).
PostPosted: March 19th, 2010, 10:17
Hi Amarbir,
could you got my PM......
Amarbir wrote:
skyyy wrote:
hi there,
TKS in advance!!
Hi ,
I Have It ,PM Me
