 Post subject: after head swap 500 Serial FLASH boot code checksum failure
PostPosted: March 13th, 2010, 16:40
hi to all
my hdd stm3500320as head failure then swap head with donor hdd
Now, hdd worked in DE and i seen data in explorer but very very slowly!?
in every second clik clik and continues
then i see in terminal
Serial FLASH boot code checksum failure!
BOOT CMD:
DS
AP <addr>
WT <data>
RD
GO
TE
BR <divisor>
RET
what's that problem?
and also
2>U
1>N1
then head clik and clik then upper message apear again
NS DATA RECOVERY
www.nsrecovery.ir
 Post subject: Re: after head swap 500 Serial FLASH boot code checksum failure
PostPosted: March 13th, 2010, 19:45
you should try to clone it very very slow.
ZeBong
" Россия еще раз"
PostPosted: March 14th, 2010, 0:58
thanks for your answere
do't chose from boot CMD?
NS DATA RECOVERY
www.nsrecovery.ir
PostPosted: March 14th, 2010, 2:13
Agree with Zebong clone it or Make image .
PostPosted: March 14th, 2010, 7:57
i do again
2>U
1>N1
then clik and clik then is done
but after power off/on hdd detect 0 byte
then i do bsy solution
now again hdd detect and see data in explorer DE
what that problem with this hdd?
8)
NS DATA RECOVERY
www.nsrecovery.ir
PostPosted: March 14th, 2010, 8:53
BOOT CMD:
DS
AP <addr>
WT <data>
RD
GO
TE
BR <divisor>
RET
Looks like damaged ROM to me. Not good on this family.If you can get the data, albeit slowly, maybe persistence and patience is the answer.
PostPosted: March 14th, 2010, 15:57
i started to image from drive
first 12 hour imaged only 30,000,000 sectors 8)
NS DATA RECOVERY
www.nsrecovery.ir
PostPosted: July 26th, 2013, 6:20
a risistor along the rom chip is lost
