 Post subject: Does ST9250315AS Momentus 5400.6 250GB have terminal access?
PostPosted: August 29th, 2013, 20:53
Hi all,
I have the following drive:
Model : ST9250315AS
Firmware : 0002BSM1
Capacity : 232.89 GB (488 397 168)
Does the following has terminal access by PC3K terminal?
The problem is that Ctrl + Z doesn't seem to work on that drive.
The drive gives terminal reports but I can't set terminal commands for it.
I am not sure if the problem is in my PC/PC3K unite or this drive doesn't has terminal access support.
What do you think?
Any terminal commands give the following terminal output:
(S) SATA Reset
Init SMART Fail
LED:000000CC FAddr:00237E89
Best Regards,
 Post subject: Re: Does ST9250315AS Momentus 5400.6 250GB have terminal acc
PostPosted: August 29th, 2013, 21:31
Thank you, I solved the case :D
