 Post subject: ST980411ASG Security Locked
PostPosted: March 25th, 2010, 6:09
Hi
i have this drive with security locked it is belongs to Momentus 7200.3 F3 Arch Family is there any way to remove security i contact Ace they told new version UDMA will support this Drive any one had solved this issue before ,
Model : ST980411ASG
F/w : DE14.
 Post subject: Re: ST980411ASG Security Locked
PostPosted: March 28th, 2010, 6:18
HI
no one solve this type of Problem before Appreciate for All comments.
PostPosted: March 28th, 2010, 8:29
did you try with seagate doctor or seagate f-level repair
datarecovery trainer and harddisk repair professional
http://www.diskanalyzers.com
PostPosted: March 28th, 2010, 9:44
HI
Thanks for reply i think am in Pc3000 support post i have UDMA.
PostPosted: March 29th, 2010, 4:34
yes you are right you are in pc3000 support but easy to fix from other tools..
thats what i want to say.. thanks for inform me.
PostPosted: March 29th, 2010, 9:09
What does this even mean?
PostPosted: March 29th, 2010, 9:32
I believe F-Level repair is a option in Salvation DAta's Sagate Doctor. Possibly a button that does absolutely nothing.
Maybe is a way of advertising for SD.....
PostPosted: March 29th, 2010, 12:12
Whatever it is, certainly it isn't going to do anything for a locked F3 drive...
PostPosted: March 29th, 2010, 13:19
SD Seagate doctor can remove ata passwords from F3 drive.
PostPosted: March 29th, 2010, 16:07
All F3?
PostPosted: March 29th, 2010, 16:42
not 100% sure. I assume so, only tested it once.
PostPosted: March 29th, 2010, 17:21
I ask because the security module is in different locations on the different families. If SD actually intelligently locates it regardless of the position then I'm surprised at them for doing something right
PostPosted: April 4th, 2010, 4:24
Thanks for all replies but i didn't get any solution yet.
PostPosted: April 5th, 2010, 2:45
http://www.ihdd.ru/forum/stm3500320as-vt7682.html
PostPosted: April 5th, 2010, 4:34
Thank u rameez i can't understand that language do u have any english link.
PostPosted: April 5th, 2010, 17:19
http://translate.google.com/translate?j ... l=ru&tl=en
PostPosted: April 5th, 2010, 17:21
PostPosted: April 6th, 2010, 2:13
Nice Picture drc Thanks for that.
