| Fujitsu 2.5" show "Restricted Mode!" http://forum.hddguru.com/viewtopic.php?f=11&t=15330 |
Page 1 of 1 |
| Author: | hdd119 [ April 2nd, 2010, 23:47 ] |
| Post subject: | Fujitsu 2.5" show "Restricted Mode!" |
Hi I has Fujitsu 2.5" hdd MHX2300BT AND MHW2120BH When i connect it to UDMA,Then UDMA display Restricter Mode! Can anyone to tell me , What fault on hdd and How to solve this problem. many thank for you |
| Author: | itconcept [ April 3rd, 2010, 5:56 ] |
| Post subject: | Re: Fujitsu 2.5" show "Restricted Mode!" |
HI connect Terminal to it and try. |
| Author: | hdd119 [ April 6th, 2010, 2:35 ] |
Thank itconcept I has connect the Terminal. and i has test another Fujitsu hdd and test is ok no "Restricter Mode!" message display. So I connect the hdd to pc3000 is ok. Can anyone get me a little suggestion. many thanx! |
| Author: | jpllal [ May 6th, 2010, 15:22 ] |
Restricted mode on newer Fujitsu drives usually indicates a bad head. |
