| HDD SECTORS http://forum.hddguru.com/viewtopic.php?f=11&t=15543 |
Page 1 of 1 |
| Author: | rafaelcm [ April 22nd, 2010, 15:32 ] |
| Post subject: | HDD SECTORS |
TESTING A NEW HDD RECEIVED HERE, I REMOVED ALL BAD BLOCKS WITH THE PC3000 AND THE MHDD, BUT, WHEN I TRY TO CREATE A NEW PARTITION IN THE PARTITION MAGIC THERE´S AN ERROR THAT SAY THAT THE SECTOR WAS NOT FOUND. HOW CAN I PROCEED??? |
| Author: | zebong [ April 22nd, 2010, 16:20 ] |
| Post subject: | Re: HDD SECTORS |
CAN YOU TURN THE CAPS LOCK OFF. Try to make a low level format. |
| Author: | hddguy [ April 23rd, 2010, 7:06 ] |
rafaelcm wrote: TESTING A NEW HDD RECEIVED HERE, I REMOVED ALL BAD BLOCKS WITH THE PC3000 AND THE MHDD, BUT, WHEN I TRY TO CREATE A NEW PARTITION IN THE PARTITION MAGIC THERE´S AN ERROR THAT SAY THAT THE SECTOR WAS NOT FOUND. HOW CAN I PROCEED??? Why would you want to create new partition and store data on a disk that has surface errors? Maybe you should jsut buy new disk. |
