| Problem with Seagate ST91208220AS Momentus PSD 120Gb http://forum.hddguru.com/viewtopic.php?f=11&t=15552 |
Page 1 of 1 |
| Author: | Powermax [ April 23rd, 2010, 6:46 ] |
| Post subject: | Problem with Seagate ST91208220AS Momentus PSD 120Gb |
Hi to all. I have a strange problem with that Seagate HDD. When i connect it to Pc3K, and power on, it start normally and no knock i can ear ( I can ear normal heads sound for start positioning, too). The problem is that the Hdd stay in Busy state. I see the terminal report at power on, is like the follow : Reset 4096k x 16 DRAM LARAMIE - 1_Disk S-1F 07-09-07_13:15 HM SFI ! (P) .FSTOP(0, 2400).FA_State(0).FA_CNT(3) LBA(FFFFFE87).LEC(0).X(18).PG(1EEF6),SABNR(88).VBM(3C88).SAVH(88,88).HVBM(3C60),LVBM(3C60).ERROUT TblRdErr NVC:Reconstructing .FSTOP(0, 2400).FA_State(0).FA_CNT(3) LBA(FFFFFE87).LEC(0).X(18).PG(1EEF6),SABNR(118).VBM(3C88).SAVH(118,118).HVBM(3BD0),LVBM(3BD0).ERROUT TblRdErr Some one can help me to solve this issue ? Thank you very mutch to all !! |
| Author: | hddguy [ April 23rd, 2010, 7:05 ] |
| Post subject: | Re: Problem with Seagate ST91208220AS Momentus PSD 120Gb |
I have not seen Laramie for a while now I think is likely that ROM may be damaged, but is not the only possibility. More thorough diagnostics are needed. |
| Author: | Powermax [ April 23rd, 2010, 7:12 ] |
May be Have you that firmware ? The correct version is 3.ALE THank you |
| Author: | pepe [ April 24th, 2010, 5:24 ] |
It is not ROM problem. See PM. |
| Author: | Eizy [ April 28th, 2010, 15:10 ] |
I have the exact same problem here. Everything sounds normal so I am hoping I can fix this without opening the drive. Thanks for your help |
| Author: | Powermax [ April 30th, 2010, 3:11 ] |
That error is related a ROM corruprion. I solved the problem to use a donor PCB with same ROM version. For me that is the only way to solve it. Thank you at all. Bye |
| Author: | hddguy [ April 30th, 2010, 6:47 ] |
Good Job |
| Author: | zebong [ April 30th, 2010, 7:12 ] |
Good to know |
| Author: | book14 [ October 30th, 2010, 15:26 ] |
Sometime it is a little difficult to find a donor PCB, and I have another solution. If somebody else is interesting in this, we can make a deal to exchange "this trick" |
| Author: | checkout [ November 20th, 2010, 6:25 ] |
Hallo great forum first, sorry for my bad english i have the same Problem. Can anybody help me please ? thank you. bye checkout |
| Author: | HDD-Chris [ September 18th, 2011, 3:10 ] |
Hi, I have a ST91608220AS (SEAGATE Momentus PSD 160GB) with these effects. The terminal-output is the following: Reset 4096k x 16 DRAM LARAMIE - 1_Disk S-1F 07-09-07_13:15 Buzz HM SFI ! (P)$($0E06C,0DC89,0000,02,18,50,0E)(R70X:8C,27,38,0D,0A,8C,27,38,0D,0A,0001,0000 )SFI AMR $($0DC89,10C7E,0000,00,27,08,0C)$($0DC89,10C7E,0000,00,2B,14,0C)$($0DC89,10C7E,0 000,00,2B,14,0C)(R70X:8C,27,38,0D,0A,8C,27,38,0D,0A,0002,0000)SFI AMR .FSTOP(0, 2400).FA_State(0).FA_CNT(1) LBA(FFFFFE17).LEC(0).X(8).PG(9C22),SABNR(18).VBM(3C98).SAVH(18,18).HVBM(3C80),LV BM(3C80).ERROUT TblRdErr NVC:Reconstructing .FSTOP(0, 2400).FA_State(0).FA_CNT(1) LBA(FFFFFE17).LEC(0).X(8).PG(9C22),SABNR(3B).VBM(3C98).SAVH(3B,3B).HVBM(3CBD),LV BM(3CBD).ERROUT TblRdErr A solution for this problem without expensive DR-services would be much appreciated. Some posts ago "book14" meant, that there are some tricks available to resolve this. Thanks in advance for your help. Regards Chris |
| Author: | mostodont [ December 13th, 2011, 3:15 ] |
Hello! I have the same problem. Can anybody help me? I can't find solution. Thanks! |
| Author: | hddguy [ December 13th, 2011, 11:14 ] |
mostodont wrote: I can't find solution. did you read this entire thread or no? |
| Author: | Tomset [ December 13th, 2011, 23:30 ] |
Merry Christmas! The contents of NVC (Flash) damaged. Medicine: T>T9F Begin Test 9F ASCII logging on Got to CertFlashBER_Clump CallingInitNvcIo() Calling M_ClearBadClumpList Calling UnlockAllNvcBlocks Calling FillBa ... Data may be lost!!! In the NVC is often MFT. |
| Author: | mostodont [ December 14th, 2011, 8:41 ] |
Thanks a lot, Tomset! But I have: Preamp ID 00 unsupported F> |
| Author: | Tomset [ December 14th, 2011, 14:11 ] |
mostodont This is far not the exact same problem. The Preamp does not see. Check the voltage at the Prеamp contacts. Replace PCB. |
