 Post subject: Maxtor Firmware help
PostPosted: April 24th, 2010, 0:47
I am a novice in dealing with some problems during the drive hope to help busy I use PC3000 under the SA testing and recovery scans the
UBA ID SIZE MODULE IMPORTANCE READ HEADER CS
496 64 1 MAXATG B YES ERROR OK
690 7B 8 FW DR YES OK ERROR
Errors leading to these two places can not partition the hard drive firmware can be solved brush it?
Hard drive model is 4D040H2220311-KMBB is hard to buy in Asia, which friends have this type of firmware hope to help to help pass the next question also want to tell me which Under 4D040H22205B1-NMDB-B9FDB-68A3 these numbers represent the hard disk What sense
 Post subject: Re: Maxtor Firmware help
PostPosted: April 24th, 2010, 2:04
How to solve
These two areas in question
Model is 4D040H2220311-KMBB
PostPosted: April 24th, 2010, 2:05
Firmware Who can give a thank you
PostPosted: April 27th, 2010, 6:45
These should be repairable within the Maxtor uility. the data inside is probably OK, just header on 1st module, and checksum on 2nd.
If you cannot do this, then I suspect no advice here will be of any use to you
Users browsing this forum: Majestic-12 [Bot] and 101 guests
