 Post subject: Needed modules WD5000AAJS-22YFA0 fw 12.01C02
PostPosted: June 2nd, 2010, 1:45
ROM can be read but not modules. Need for ~Dir.rpm.
 Post subject: Re: Needed modules WD5000AAJS-22YFA0 fw 12.01C02
PostPosted: June 2nd, 2010, 3:57
Module ~Dir is different for different versions of F/W !!!
PS Please place here the log window from the PC-3k ...
Mikippp
PostPosted: June 2nd, 2010, 4:21
This is from log:
Techno mode key:
RAM table reading Cmd sending error Device Error Detected 51/04 (ABR)
PostPosted: June 2nd, 2010, 4:23
And when started on Kernel mode:
Techno mode key:
Read ROM................................ : Ok
ROM version............................. : 58.76D
ROM generation.......................... : 58.76D
Link table version...................... : 01.0F.
Heads configuration..................... : Default
PostPosted: June 2nd, 2010, 9:39
You need to use Marvell utility instead of WDC32 utility.
PostPosted: June 2nd, 2010, 17:04
Yes, that's correct. My mistake. Thank you.
Users browsing this forum: No registered users and 87 guests
