WD read only SA
http://forum.hddguru.com/viewtopic.php?f=11&t=16063
Author:  bfg [ June 11th, 2010, 20:39 ]
Post subject:  WD read only SA
hello
does anyone know what to do in the case where pc3000 does not want to write any modules into WD drive.
it returns some error. i tried overwriting several modules good or bad without success.
it seems the SA is read only.
this is newer drive.
thanks
BFG
Author:  drc [ June 11th, 2010, 21:52 ]
Post subject:  Re: WD read only SA
You'll probably need to be more specific than that.
Author:  bfg [ June 12th, 2010, 2:01 ]
wd5000bevt
it has bad loader module 11. all the other modules are OK
pc3000 returns "error code:3745" when attempting to write any module.
this includes 11 or even good module.
it will not clear G-list or set password.
so no write access to SA. it can only read SA
thanks
B
Author:  msurgeon [ June 14th, 2010, 12:48 ]
What was the original problem with the drive? Bad heads/ damaged SA area can often prevent modules from being written.
Author:  bfg [ June 14th, 2010, 13:09 ]
it seems module 11 has been the only problem. the drive is not even opened.
thanks
Author:  poehere [ June 14th, 2010, 13:30 ]
Did you try to do a hot swap with another HDD identical and write the modules? What version of PC3000 PCI or UDMA? UDMA there is hotswap procedure you can use on this one.
Author:  bfg [ June 15th, 2010, 19:19 ]
i already tried hot swap and it did not do. drive clicks. it is possible i dont have fully compatible drive for this.
are there any tricks to it?
thanks
Author:  hddguy [ July 5th, 2010, 5:15 ]
This is because you do not have SA copies available. If ATA mod #11 is bad, you cannot read and write to ABA. Try using LDR from compatible donor disk, or quit trying to read/write to ABA...
Author:  bfg [ July 5th, 2010, 14:02 ]
i can read all modules but 11. i already have them all. i also have matching module 11 from donor and i am unable to write it to the SA. i have no write access to SA at all. i agree that bad module 11 is most likely causing this issue. i wonder if there is a way around it.
Author:  Touchclarity [ January 12th, 2011, 11:43 ]
Hi, did you ever solve this issue? I am experiencing the same problem here with a WD5000AAKS, ROM appears fine, and i can read all other modules except 11 (0x0:) Drive will not allow me overwrite or edit any other modules.
Did you get any answers on this?...
