HDD GURU FORUMS
http://forum.hddguru.com/
pc3k USB Terminal Question
http://forum.hddguru.com/viewtopic.php?f=11&t=16313
Page 1 of 2
Author:  einstein9 [ July 8th, 2010, 8:23 ]
Post subject:  pc3k USB Terminal Question
Greetings,
i have a problem with the pc3k USB Terminal which i never found the answer yet
please any help/advice???
i tried to connect a working HD Segate ST9120823AS FW: 3.AHE
using the small segate usb adapter as in here attach.
the problem is that in hyperterminal there is no output nothing shows
i tried "Ctrl+Z" or "." no changes
but i noticed that the USB Terminal Adapter Blinks RED with every key i press in hyperterminal
is there any idea or why am having this problem of no output
help appreciated guys
Author:  drc [ July 8th, 2010, 9:22 ]
Post subject:  Re: pc3k USB Terminal Question
The simplest explanation is frequently the correct one
Author:  einstein9 [ July 8th, 2010, 9:23 ]
what do u mean by this?
Author:  drc [ July 8th, 2010, 9:29 ]
You have it plugged in upside down
Author:  Zero Alpha [ July 8th, 2010, 9:33 ]
There are 2 things wrong. Lucky its an apple drive as you can't do anymore harm.
Author:  einstein9 [ July 8th, 2010, 9:36 ]
i tried both sides with the same
Author:  einstein9 [ July 8th, 2010, 9:38 ]
Zero Alpha. could u plz be more specific?
Author:  Cleanroom [ July 8th, 2010, 12:33 ]
no power, and the adapter (connected to the drive) is upside down.
Those are the two things
Author:  HWHacker [ July 8th, 2010, 12:56 ]
First make sure the settings in HT are correct (38000,n,8,1). Second make sure "echo" is off in HT so you do not see your own typing unless it is being echoed from the drive. Next jumper the TX and RX lines on the PCB header that plugs into the drive you should see your key strokes echoed. If this works your hardware is good. Then try the drive again again. If it fails after that try a different drive.
Hope this helps
Author:  HWHacker [ July 8th, 2010, 13:02 ]
Yes drive power would be good. And who builds (uses) a connector without the polarization tab ???? Come on people don't we care ???
Author:  drc [ July 8th, 2010, 13:52 ]
He is not using hyperterminal...
Author:  HWHacker [ July 8th, 2010, 17:06 ]
Just use HT if USB serial is a COM and you want to verify hardware.
Author:  Zero Alpha [ July 9th, 2010, 5:49 ]
Yes you need power and connect right way up. Is it a genuine pc3000? because it is explained in your manual.
Author:  rameez [ July 9th, 2010, 15:33 ]
One more thing if its not one of the newer drives you need to set baud rate 9600.
Author:  einstein9 [ July 10th, 2010, 8:35 ]
Cleanroom
Bingooo
this is the one, believe it or not
its been like 2 weeks and am suffering with acelab support, i swear none gave me the direct answer
thnx Cleanroom for ur help really and all the others as well...
Author:  porthas [ July 29th, 2010, 14:11 ]
ACELAB's support fails, when you use email. Ask them via Skype. Acelaboratory.support - Tech support for international customers. aceelena - billing and sales.
There are others, but these are the general ones.
Author:  lcoughey [ July 29th, 2010, 14:40 ]
Einstein, eh? ;)
Author:  granaryloaf [ July 30th, 2010, 9:35 ]
See below:
Author:  guru [ July 30th, 2010, 10:50 ]
@DRC "You have it plugged in upside down" Quote of the year LOOOOOOOOOOOOOOOOOOOOOOOOOOL
einstein ? LOL sorry thats a giggle
Author:  einstein9 [ July 31st, 2010, 3:13 ]
thnx granaryloaf for the details here
and as i said the ace support did not notice this because i sent the same photos to them
and did not get the proper answer but i found it here.
thnx all for ur help again and again
:roll:
Page 1 of 2 All times are UTC - 5 hours [ DST ]
http://www.phpbb.com/
