 Post subject: Firmware needed: Ver. 000500E0 for WD3200AAJS-00L7A0
PostPosted: July 27th, 2010, 18:32
I need firmware for a WD3200AAJS-00L7A0. The firmware revision in the modules comes up as 000500E0. The drive is a WD Marvell, Pinclite family. The modules in particular that I need are 41, 42, 43, 49, and 03. I am aware that these are unique adaptives for the drive. Unfortunately, composite reading by ABA is unsuccessful and the ACE support folks say this particular drive is often successful with identical firmware replacement.
Any help is appreciated. Thanks!
 Post subject: Re: Firmware needed: Ver. 000500E0 for WD3200AAJS-00L7A0
PostPosted: August 20th, 2010, 17:45
SN?
PostPosted: August 20th, 2010, 18:09
Serial is WMAV25440320. Thanks for checking.
Steve
PostPosted: August 20th, 2010, 18:20
i found those
tell me which one u prefer and closest btw some of them are rom only
just see the list and i will double chk it for u
PostPosted: August 20th, 2010, 18:21
forgot to mention PM the one u wanted
PostPosted: August 21st, 2010, 13:49
pm sent BytesBack
PostPosted: August 23rd, 2010, 13:43
BytesBack
chk ur email files sent
PostPosted: March 20th, 2011, 18:26
hello einstein9
I need firmware for
WDC WD3200AAJS-00L7A0-01.03E01-WD-WCAV23209160 22 jun 2009
thanks...
PostPosted: March 23rd, 2011, 4:17
elkadylove wrote:
hello einstein9
I need firmware for
thanks...
You'd probably get a better response if you started your own thread, rather than tagging onto this one.
