 Post subject: Freak WD800bb-75jhco
PostPosted: July 14th, 2008, 7:52
i have hdd WD800bb-75jhco it works ok
all module ok
sa ok
i format it and clear smart and i used WD clear but the hard still have it's partions and Data :( what should i do
Tawfeek Mokhtar
http://alsafwapc.net
Alsafwa Data Recovery Egypt
 Post subject: Re: Freak WD800bb-75jhco
PostPosted: July 14th, 2008, 14:20
lowlevel format the drive .
PostPosted: July 14th, 2008, 15:40
i do low level format olso and partions still here !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! what the hell is that
Tawfeek Mokhtar
PostPosted: July 14th, 2008, 16:07
Use a hammer. :mrgreen:
Or try to simple overwrite the sectors if you want to destroy the data.
Janos
PostPosted: August 13th, 2008, 21:10
I am afraid there's something wrong with writing to the media. Either PCB, preamp or head...
PostPosted: August 12th, 2010, 23:17
and now, for the actual correct answer.... doing a low level format, or clearing the smart, has absolutely nothing to do with the partitioning of the drive, if you boot your pc with the western digital data lifeguard tools, go to the "setup HardDrive" option, select the OS from the list that you intend to install, it will then give you an option for an easy installation, or advanced, choose advanced, click on the clear button option, then the add button option, use full drive capacity for a primary partition, check the box to allow deletion and formatting and click format, when completed goahead restart put os cd in drive and enjoy yuor freshly partitioned HDD.
your welcome in advance
PostPosted: August 13th, 2010, 4:41
... and the answer is wrong. :D
Low lever format SHOULD clear the partition table as well.
This drive is failing, and nobody can use any of sw installers to handle it.
Janos
PostPosted: August 15th, 2010, 6:42
Maybe heads have become read only , it happens it reads fine but doesn't write anything .
PostPosted: August 16th, 2010, 11:26
This is highly possible. I have seen it in WD400BB HD's in the past.
PostPosted: August 16th, 2010, 11:48
Strange. try to do a write test to like the first sectors of the ddrive - power reset and verify if it wrote it.
Free Solutions
