 Post subject: HELP WITH ROM FOR WD5000AAVS-OOZTB0
PostPosted: August 8th, 2010, 11:12
Any help here with fw for this drive
MODEL: WD5000AAVS-OOZTB0
SN: WCASU0909163
thnx in advance
 Post subject: Re: HELP WITH ROM FOR WD5000AAVS-OOZTB0
PostPosted: August 11th, 2010, 7:14
guys, does it mean no one has this fw or lazy to search for a minute and post here what he has!!!
thnx again in advance
PostPosted: August 11th, 2010, 8:33
What do you want, a full dump of the FW? You realize they're all different, right?
PostPosted: August 15th, 2010, 10:29
thnx for the reply drc
i wanted the full fw plz the closest to its SN: WCASU0909163
thnx again
PostPosted: August 16th, 2010, 4:06
You need to be more specific with what you want. Not all firmware can be interchanged/replaced, and much of the firmware is at least specific to a frmware revision.
Using the wrong firmware can have bad consequences and irrepairable results.
PostPosted: August 16th, 2010, 4:52
You have UDMA? If so there should be at least ROM version in your log.
PostPosted: August 16th, 2010, 8:42
hddguy
well i guess the closest to the SN might work since its already not working
and worth to try.
right?
PostPosted: August 16th, 2010, 8:53
erm can you not read the ROM even in Kernel mode?
PostPosted: August 16th, 2010, 14:08
I think he has SD WD Doctor and it is not possible to do this in Kernel mode on this tool. It is possible to read the ROM but SD does not support Kernal mode or at least I can not make it work on this tool. If his drive is ready and stops spinning in SD tool he can go to the file and open this and after go to rom and read the rom from there. That is only way I have found it works on this tool. I can not put the pcb in safe mode on this tool so far and make it work for me.
Guess what he is looking for is a FW back up from another drive done on SD WD Doctor. This way he can have the mod, tks, rom for him on this one.
Iorana Haraharaini
PostPosted: August 16th, 2010, 14:26
poehere
thnx and you are right here
and btw i have both SD & pc3k
so any backup for this drive guys?
and thnx again in advance
PostPosted: August 16th, 2010, 14:32
SD WD cannot do Kernel mode? Why is that?
PostPosted: August 16th, 2010, 15:43
so no one has it guys???
PostPosted: August 16th, 2010, 16:08
There's one in the files section.
PostPosted: August 16th, 2010, 16:55
thnx alot drc
and also thatdellguy
i supposed to look there 1st.
:oops:
PostPosted: August 16th, 2010, 21:01
You asked for ROM here it is. This one is from SD to use in your tool.
ROM.rar [159.89 KiB]
Downloaded 559 times
Iorana Haraharaini
PostPosted: August 17th, 2010, 6:50
thnx poehere
many thnx
:idea:
