 Post subject: HDDFiles Search Problem
PostPosted: August 17th, 2010, 15:06
Dear Admins
i guess there is a problem with the search on the forum files search API
always gives problems there so could you please fix this issue
thnx
 Post subject: Re: HDDFiles Search Problem
PostPosted: August 25th, 2010, 18:07
Thanks for the head up, the issue is fixed.
Dmitry
PostPosted: August 26th, 2010, 7:52
Hi, thnx for the reply here but seems that the API has some problems with results
have a quick test and see
thnx again:>
PostPosted: August 26th, 2010, 16:00
I tried several searches, but everything seems to be fine. What is the issue that you are experiencing?
Dmitry
PostPosted: August 26th, 2010, 16:35
as an example here
enter this folder:
http://files.hddguru.com/download/PC-30 ... t/Fujitsu/
u will see many fujitsu, try to search for: mhy22
it should show something at least from the folder which already exist but doesn`t show as result
check it ur self and see
and thnx again for the reply :mrgreen:
PostPosted: August 26th, 2010, 18:37
Google can only search whole words, it won't be able to locate something like that... unfortunately.
Dmitry
PostPosted: August 26th, 2010, 18:53
thnx for the reply
i was checking and ur right @ least 9 char. in search less will not work
just for the info
:mrgreen:
