| SD tools & PC3k help http://forum.hddguru.com/viewtopic.php?f=11&t=16773 |
Page 1 of 1 |
| Author: | einstein9 [ August 21st, 2010, 14:25 ] |
| Post subject: | SD tools & PC3k help |
Dear Experts How do i use the SD resources in PC-3000 like the ROM/Modules/Tracks i know that in Pc-3000: Modules Extension is: RPM Tracks : .map & .trk loader is: .LDR and in SD: Modules Extension is: .mod Tracks : .tks loader is: ??? so could someone please answer this question for me because am stuck somewhere here with my resources my Questions: I tried to rename from SD to Pc-3000 but where is the Loader in SD? to use it in PC-3000 and so on thnx in advance guys |
| Author: | Clusterox [ August 22nd, 2010, 13:21 ] |
| Post subject: | Re: SD tools & PC3k help |
You manually need to edit the modules (split, joint and other such actions) in raw hex mode, in order to make them cross compatible. |
| Author: | einstein9 [ August 22nd, 2010, 14:19 ] |
Clusterox wrote: You manually need to edit the modules (split, joint and other such actions) in raw hex mode, in order to make them cross compatible. well, could you please be more specific here, i mean split,join in hex may i have an example ... thnx |
| Author: | irs [ August 24th, 2010, 3:56 ] |
i think the problem is that you can't simply rename: the loader in maxtor is quite different in pc3k you have a .ldr file and in SD is boot.cod file but loader operation is a little bit different (sd loader involve more modules). NVRAM file of hitachi on the other side is the same and you can use on both (a simple dump |
| Author: | Clusterox [ August 24th, 2010, 4:31 ] |
Just for the reference, here is the the conversion table for Seagate U6: Salvation Modules Name PC3000 Modules Name (In STU6_1.mod format) (In .RPM Format) 1 ----- RWF 2 ----- AT_STUFF 3 ----- SMART 4 ----- CSPT 5 ----- OVLY_CCT 6 ----- OVLY_ACT 7 ----- OVLY_CN1 8 ----- UDEFBAK 9 ----- USERDEF 10 ----- RESVDEF 11 ----- OVLY_AN1 12 ----- SYSVAR1 17 ----- OVLYA 22 ----- SECURITY 23 ----- OVLY_AT1 24 ----- VENDORSP However, it's doesn't mean that won't need my previous advice! |
| Author: | einstein9 [ August 24th, 2010, 6:16 ] |
thank you thank you really all of you here for the reply, but may i ask this specific question about this matter in case of WD HDD only, i will take this example as a reference for me and i will compare it with the rest can i have this example please in both SD & pc3k? lets say the Marvell thank you again guys for the time and reply |
| Author: | einstein9 [ August 25th, 2010, 8:16 ] |
i do believe that there are a lot of secrets here and No One wants to share some tips soon or later it will come. thnx for ur advices n tips |
