 Post subject: needed firmware for st3320613as
PostPosted: September 4th, 2010, 14:08
hi
please i need firmware for st3320613as
s/n : 9sz1psse
firmware : cc2f
i need firmware because hdd's firmware is corupted
thanks
 Post subject: Re: needed firmware for st3320613as
PostPosted: September 5th, 2010, 4:27
I don't believe that Seagate has offered any CCxx firmware downloads for the 7200.11 series. In any case, DO NOT be tempted to use SDxx firmware on your drive. If you do, you will brick it.
That said, what is wrong with your drive? What are its symptoms?
