| Seagate Freeplay 1TB ST91000430AS http://forum.hddguru.com/viewtopic.php?f=11&t=16999 |
Page 1 of 1 |
| Author: | einstein9 [ September 14th, 2010, 9:54 ] |
| Post subject: | Seagate Freeplay 1TB ST91000430AS |
guys any clue i got this HDD ST91000430AS SN: 9YE0KFPT FW: CC9D in pc3k it clicks few seconds and then can read Model/Serial/FW but the capacity is MB() can anyone please tell me where is the problem here? is it modules problem? any clues??? many thnx btw: pc3k says: WARNING! It`s probably HDD have "HDD Lock (LED: 000000CC)" problem Try the command: Solution for problem "HDD Lock (LED: 000000CC)" From menu: Tests -> Solutions i tried it but results are: HDD Readiness timeout (10000 ms) D0 / 00 |
| Author: | Cleanroom [ September 14th, 2010, 10:14 ] |
| Post subject: | Re: Seagate Freeplay 1TB ST91000430AS |
So it does come ready, just with a zero size? Did you try the other solution for the To fix just the size? You can try and manually regen the translator from the terminal window. It could also be a failing head. |
| Author: | einstein9 [ September 14th, 2010, 10:49 ] |
i did reg. translater but the same HDD Readiness timeout and what is the other solution for the size fix? many thnx |
| Author: | hddguy [ September 14th, 2010, 11:11 ] |
Maybe the problem is not SA related. If heads knock before identifying as 0MB maybe there is physical fault and ID is read from ROM alone. Did you try some other harmless commands like V4 to see if surface can be read? |
| Author: | einstein9 [ September 14th, 2010, 11:23 ] |
hddguy wrote: Maybe the problem is not SA related. If heads knock before identifying as 0MB maybe there is physical fault and ID is read from ROM alone. Did you try some other harmless commands like V4 to see if surface can be read? well,, no i did not yet, since am not good in terminal commands for seagate but am reading before doing anything stupid |
| Author: | einstein9 [ September 18th, 2010, 4:50 ] |
hello again guys,, again the same problem, i did try the: Solution for problem "HDD Lock (LED: 000000CC) which is putting an isolation on between the PCB & Motor and tested it but did not work with me here is the log: Test : Solution for problem "HDD Lock (LED: 000000CC)" Switching HDD power supply OFF Switching HDD power supply ON COM port reconnection... Spin Up... ExecuteSpinRequest FAIL Op=0100 Resp=0003 FAIL Op=0100 Resp=0003 FAIL Op=0100 Resp=0003 FAIL Op=0100 Resp=0003 FAIL Op=0100 Resp=0003 FAIL Op=0100 Resp=0003 FAIL Op=0100 Resp=0003 FAIL Op=0100 Resp=0003 FAIL Op=0100 Resp=0003 FAIL Op=0100 Resp=0003 FAIL Op=0100 Resp=0003 DiagError 00006008 Spin Error Elapsed Time 7.130 secs R/W Status 2 R/W Error 84150180 F3 2> Drive not ready |
| Author: | einstein9 [ September 18th, 2010, 6:13 ] |
i tried to access the HDD using hyperterminal after powering the HDD and i saw this log in HT: [^ûæ{j[½A{Z{öa{6Õz·LÑV…«v¿Eu7¶6þEu7¶6þEu7¶6þ0`¶6þEA¶6þEu76þEu7¶6þEu7 6þEÁ7¶6þEu7¶6þEu7¶6 ?„lGJê clicks few times (11 times) then not accepting any command any help plz |
| Author: | einstein9 [ September 18th, 2010, 6:22 ] |
in pc3k terminal here is the LOG: LED:000000CC FAddr:002519BB LED:000000CC FAddr:002519BB LED:000000CC FAddr:002519BB LED:000000CC FAddr:002519BB LED:000000CC FAddr:002519BB LED:000000CC FAddr:002519BB LED:000000CC FAddr:002519BB and i cannot type any command there !!!! |
| Author: | einstein9 [ September 18th, 2010, 8:26 ] |
HT Log : ____________________________isolating the Pins log ExecuteSpinRequest FAIL Op=0100 Resp=0003 FAIL Op=0100 Resp=0003 FAIL Op=0100 Resp=0003 FAIL Op=0100 Resp=0003 FAIL Op=0100 Resp=0003 FAIL Op=0100 Resp=0003 FAIL Op=0100 Resp=0003 FAIL Op=0100 Resp=0003 FAIL Op=0100 Resp=0003 FAIL Op=0100 Resp=0003 FAIL Op=0100 Resp=0003 Send Status: COMRESET seen ASCII Diag mode F3 T>/2 F3 2>Z Spin Down Complete Elapsed Time 0.132 msecs F3 2>U ExecuteSpinRequest FAIL Op=0100 Resp=0003 FAIL Op=0100 Resp=0003 FAIL Op=0100 Resp=0003 FAIL Op=0100 Resp=0003 FAIL Op=0100 Resp=0003 FAIL Op=0100 Resp=0003 FAIL Op=0100 Resp=0003 FAIL Op=0100 Resp=0003 FAIL Op=0100 Resp=0003 FAIL Op=0100 Resp=0003 FAIL Op=0100 Resp=0003 DiagError 00006008 Spin Error Elapsed Time 7.182 secs R/W Status 2 R/W Error 84150180 F3 2>/1 F3 1>N1 Failed to load overlay 00000004 LED:000000CC FAddr:0026E6CF LED:000000CC FAddr:0026E6CF LED:000000CC FAddr:0026E6CF |
| Author: | einstein9 [ September 19th, 2010, 10:25 ] |
einstein9 wrote: i tried to access the HDD using hyperterminal after powering the HDD and i saw this log in HT: [^ûæ{j[½A{Z{öa{6Õz·LÑV…«v¿Eu7¶6þEu7¶6þEu7¶6þ0`¶6þEA¶6þEu76þEu7¶6þEu7 6þEÁ7¶6þEu7¶6þEu7¶6 ?„lGJê clicks few times (11 times) then not accepting any command any help plz cos i was using wrong BR, 38400 for this drive |
| Author: | einstein9 [ September 20th, 2010, 3:21 ] |
many thanks to Fabio really for his Quick Tips/Help this issue is finished |
| Author: | Denis_d [ November 29th, 2010, 3:22 ] |
einstein9 wrote: many thanks to Fabio really for his Quick Tips/Help this issue is finished Can i know how you fix problem - i have same situation. Thanks |
| Author: | fzabkar [ December 1st, 2010, 8:41 ] |
einstein9 wrote: einstein9 wrote: i tried to access the HDD using hyperterminal after powering the HDD and i saw this log in HT: [^ûæ{j[½A{Z{öa{6Õz·LÑV…«v¿Eu7¶6þEu7¶6þEu7¶6þ0`¶6þEA¶6þEu76þEu7¶6þEu7 6þEÁ7¶6þEu7¶6þEu7¶6 ?„lGJê clicks few times (11 times) then not accepting any command any help plz cos i was using wrong BR, 38400 for this drive The garbled data contain 11 repeating groups of 7 characters. One could expect that the garbled groups represent the following 24 bytes of text: FAIL Op=0100 Resp=0003<cr><lf> Assuming a ratio of 4:1 (~24:7), then one could expect that the correct baud rate would be 4x the garbled baud rate. So I'm guessing that you were initially using 9600 baud. |
| Author: | ragadatasolutions [ December 24th, 2010, 3:41 ] |
how to handle the same situation with Salvationdata product???? (or) how to change the baud rate inside Salvationdata product? |
| Author: | irs [ December 24th, 2010, 6:03 ] |
@ ragadatasolutions: why change BR? is already set for SEAGATE. You can use the A button on terminal windows is the Auto baud function. You can change it manually on samsung doctor and i think in Fujitsu/toshiba only. Bye Luca |
| Author: | talpina [ April 21st, 2011, 12:02 ] |
hi, me too have a trouble problem with this hdd. i can read via usb under seven or vista, but it say is a 2 tb. of course no partition or data is readable. any could help me to try to recovery? the hdd before falling down by a table. it was not fully working and my friend try to do a scandisk. after scandisk the hdd was died. at hdd starts i hear some ticks and later no more sounds. i readed that u can interface viaa serial, is possible to do whitout any hw support? if u can help me i wil appreciate a Lot. Tks Giorgio |
| Author: | Vulcan [ April 21st, 2011, 12:34 ] |
This is the wrong forum for your question, because it is not related to using the PC-3000 data recovery equipment. Please ask any further questions here: hard-disk-drives-data-recovery-and-repair-f1.html talpina wrote: it say is a 2 tb. [...] of course no partition or data is readable. [...] the hdd before falling down by a table. [...] at hdd starts i hear some ticks These pieces of information all mean that the drive has suffered internal damage (head/media) and so there is no recovery that you can sensibly do - cleanroom work will be required. If the data is important, you will need to use the services of a suitable DR company - you can request recommendations on the forum I linked above. Sorry for the bad news. Good luck! |
| Author: | talpina [ April 21st, 2011, 16:42 ] |
tks for info. may be i will cry |
