| WD10EAVS & Data Extractor help http://forum.hddguru.com/viewtopic.php?f=11&t=17114 |
Page 1 of 1 |
| Author: | Cleanroom [ September 24th, 2010, 9:55 ] |
| Post subject: | Re: WD10EAVS & Data Extractor help |
Could be encrypted data. |
| Author: | dobrevjetser [ September 24th, 2010, 10:34 ] |
Disk can have XFS also or even more exotic so DE wont recognize it. First clone it and then check with winhex or ufs explorer. Dobre |
| Author: | hddguy [ September 24th, 2010, 10:42 ] |
In image I see 'ABR' error. Is possible that surface is not accesible at all and no data can be found because surface is not reading. Can you confirm if surface can be read OK ? |
| Author: | lcoughey [ September 24th, 2010, 10:54 ] |
I would start with fixing the drive to allow sector access from within the WD utility...with these drives, this is not a process that I'm willing to explain, let alone in a public forum. I recommend you seek assistance from ACE. |
| Author: | zebong [ September 24th, 2010, 17:07 ] |
why do you not edit some sectors to see what is there |
| Author: | einstein9 [ September 28th, 2010, 7:24 ] |
Thnx goes to hddguy poehere and fabio for the quick tips and feedback this issue been resolved thank you all |
