 Post subject: Seagate LDR required
PostPosted: October 8th, 2010, 8:16
ST3250824A
3.AAE
TIA!!!!
 Post subject: Re: Seagate LDR required
PostPosted: October 8th, 2010, 11:26
Sent.
www.datarecoveryne.com
PostPosted: October 8th, 2010, 12:18
Thanks!
The LDR worked OK.
Now making head map as I suspect the surface pertaining to H3 will be suspect, as this was a "DIY Special"
Original problem - Seized (straightforward platter swap on 250Gb)
Additional problem - Drive opened by user and top platter COVERED in dust and finger prints, like they had opened it in a fluff factory!
So the platters have been swapped, top platter cleaned, heads changed and LDR used to gain access (overlay 1 bad).
PostPosted: October 8th, 2010, 22:19
I hope you charged upfront for this.
Zero Alpha: zeroalpha.com.au
PostPosted: October 9th, 2010, 13:01
No, but charging double regular rate for seized.
