| Seagate LDR required http://forum.hddguru.com/viewtopic.php?f=11&t=17288 |
Page 1 of 1 |
| Author: | pcimage [ October 8th, 2010, 8:16 ] |
| Post subject: | Seagate LDR required |
ST3250824A 3.AAE TIA!!!! |
| Author: | harddrivespecialist [ October 8th, 2010, 11:26 ] |
| Post subject: | Re: Seagate LDR required |
Sent. |
| Author: | pcimage [ October 8th, 2010, 12:18 ] |
Thanks! The LDR worked OK. Now making head map as I suspect the surface pertaining to H3 will be suspect, as this was a "DIY Special" Original problem - Seized (straightforward platter swap on 250Gb) Additional problem - Drive opened by user and top platter COVERED in dust and finger prints, like they had opened it in a fluff factory! So the platters have been swapped, top platter cleaned, heads changed and LDR used to gain access (overlay 1 bad). |
| Author: | Zero Alpha [ October 8th, 2010, 22:19 ] |
I hope you charged upfront for this. |
| Author: | pcimage [ October 9th, 2010, 13:01 ] |
No, but charging double regular rate for seized. |
