WD400BD
Posted: October 11th, 2010, 14:35
Hello all the Gurus. Working with a WD-400BD. Drive was clicking. Original drive has 1 head only. Found a donor that had 2 heads. Performed head swap. Patient Drive spins up and ID's itself with correct Model and firmware in PC-3000. I am not sure what to do next. I am not so good with PC-3000 and still learning. Any help would be greatly appreciated . PLease see the SA structure report below. Thanks
Techno mode key
Techno mode key......................... : Ok
RAM:
Zone allocation table................... : Ok
Cyl Count............................... : 83935
SA SPT.................................. : 533
Head number reading..................... : Ok
Heads number............................ : 1
ROM:
ROM reading............................. : Ok
ROM Data size........................... : 128 Kb
ROM version............................. : 06.BGD
ROM generation.......................... : 06.BGD
Link table version...................... : 01.B3.
Heads configuration..................... : by map
Heads number in use..................... : 1
Switched off heads...................... : No
Head map................................ : 1
Firmware version........................ : 06BG?
Service area:
SA dir reading.......................... : Ok (Copy 0)
Configuration reading................... : Ok
Master Password......................... : has not been set
User Password........................... : has not been set
Soft reset ...
Hard reset ...
Modules checking
Module 01............................... : Ok
Module 31............................... : Ok
Module 17............................... : Ok
Module 15............................... : Ok
Module 04............................... : Ok
Module 4A............................... : Ok
Module 52............................... : Ok
Module 35............................... : Ok
Module 02............................... : Ok
Module 33............................... : Ok
Module 26............................... : Ok
Module 1C............................... : Ok
Module 4C............................... : Ok
Module 07............................... : Ok
Module 53............................... : Ok
Module 2E............................... : Ok
Module 1B............................... : Ok
Module 19............................... : Ok
Module 41............................... : Ok
Module 05............................... : Ok
Module 0C............................... : Ok
Module 37............................... : Ok
Module 2D............................... : Ok
Module 21............................... : Ok
Module 1E............................... : Ok
Module 40............................... : Ok
Module 32 (Translator).................. : Module read error: Physical read error C/H/S: -8/0/420 Techno CMD sending error Device Error Detected: "DISK ECU UNSAFE ERROR"
Module 32............................... : Error
Module 36............................... : Ok
Module 11............................... : Ok
Module 23 (S.M.A.R.T. Log (reserved))... : Module read error: Physical read error C/H/S: -9/0/263 Techno CMD sending error Device Error Detected: "DISK ECU UNSAFE ERROR"
Module 23............................... : Error
Module 43............................... : Ok
Module 39............................... : Ok
Module 2F............................... : Ok
Module 49............................... : Ok
Module 38............................... : Ok
Module 22............................... : Ok
Module 28............................... : Ok
Module 34 (G-List (Grown defect list)).. : Module read error: Physical read error C/H/S: -10/0/352 Techno CMD sending error Device Error Detected: "DISK ECU UNSAFE ERROR"
Module 34............................... : Error
Module 29............................... : Ok
Module 50............................... : Ok
Module 25............................... : Ok
Module 24............................... : Ok
Module 42............................... : Ok
Module 06............................... : Ok
Module 2A............................... : Ok
Module 51............................... : Ok
Module C4............................... : Ok
Module C5............................... : Ok
Module CC............................... : Ok
Module CA............................... : Ok
Module CB............................... : Ok
Module CD............................... : Ok
Module CF............................... : Ok
Module CE............................... : Ok
Module 91............................... : Ok
Module 92............................... : Ok
Module 93............................... : Ok
Module C1............................... : Ok
Module C2............................... : Ok
Module C7............................... : Ok
Module 9E............................... : Ok
Module B1............................... : Ok
Module E0............................... : Ok
Module E8............................... : Ok
Module FE............................... : Ok
Module D5............................... : Ok
Module DA............................... : Ok
Module DB............................... : Ok
Module DF............................... : Ok
Module DD............................... : Ok
Module D6............................... : Ok
Module D7............................... : Ok
Module D2............................... : Ok
Module BB............................... : Ok
Module D9............................... : Ok
Module D4............................... : Ok
Module DC............................... : Ok
Module D0............................... : Ok
Module D3............................... : Ok
Module BA............................... : Ok
Module B9............................... : Ok
Module BC............................... : Ok
Module FD............................... : Ok
Module FB............................... : Ok
Module E6............................... : Ok
Module E7............................... : Ok
Module BE............................... : Ok
Module B8............................... : Ok
Module BF............................... : Ok
Module FC............................... : Ok
Module EE............................... : Ok
Module E1............................... : Ok
Module E2............................... : Ok
Module E3............................... : Ok
Module E4............................... : Ok
Module E5............................... : Ok
Module E9............................... : Ok
Techno mode key
RAM:
ROM:
Service area:
Soft reset ...
Hard reset ...
Modules checking
