 Post subject: NEED ROM FOR WD2500JD-00HBC0
PostPosted: October 16th, 2007, 8:34
Hi everyone,
Does anyone have ROM for the following drive?
MDL WD2500JD-00HBC0
FIRM 08.02D08
ROM VERSION 21.DCJ
I need it as soon as possible so any help would be really appreciated.
Thanks in advance
Maestro
hard_disk_maestro@hotmail.com
 Post subject: Re: NEED ROM FOR WD2500JD-00HBC0
PostPosted: October 16th, 2007, 8:40
Hi Maestro,
I have version 21.02J
Do you want to try it ?
Do you have UDMA? Export is only for this version.
Regards,
Dobre
Murphy was an optimist
PostPosted: October 16th, 2007, 9:02
Hi Dobre,
Yes i am using UDMA version so if you can send it to give it a try?
Thanx
Maestro
PostPosted: October 22nd, 2010, 5:47
Hi to all! Does anyone STILL have the rom for that drive? I've got the same problem of maestro, and I have, of course, the UDMA version, thank a lot, bye
PostPosted: October 22nd, 2010, 14:01
Here you are...
Rom.rar [123.09 KiB]
Downloaded 451 times
Info.txt [974 Bytes]
Downloaded 665 times
PostPosted: October 22nd, 2010, 18:58
PM me if you want a full copy of ROM & Firmware,
best wishes,
John
0161 408 4857
